"ColorBack" - Anyone Use it?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: "ColorBack" - Anyone Use it?
    Posted: 21 Jul 2019 at 11:58pm
It seems too good to be true...just spray it on and equipment is good as new? Anyone tried it?
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 7:06am
Looking at the website is it just clear coat? I have seen people spraying clear coat over rough paint to get a sheen like that I just wonder if that what it is.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 8:08am
I can't see how it works without eliminating the oxidized paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 9:27am
It does seem like just a clear coat, with UV protection additives. I guess it’d make the equipment look good for a while, but if it ever started coming off...
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 9:54am
you said it when it starts coming off  ,  look at what vechles look like when the clear starts coming off and it will unlesss it sitts in the garage 99% of its life
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 12:24pm
Right, that's what I was picturing.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 12:47pm
I used something like that on a Florida sun-bleached GMC Jimmy about 20 years ago.  It worked OK, but did not make it look like new paint.  That was an acryilic product that did come off over time, but not like an lacquer or enamel clear coat.  It didn't peal off, it just kind of went away gradually over time and it could be reapplied.  It was like one day you realized it was dull again.
I don't know if this is similar, but if I had something faded that I didn't want to paint, I'd try something like the stuff I used years ago again.
1951 B
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 2:24pm
Rustoleum has a similar product called "Wipe-New"
https://www.rustoleum.com/product-catalog/consumer-brands/wipe-new/
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 3:30pm
Read on some other forums that you need to degrease real well, scoff it up with a scotchbrite, and spray the stuff on heavy to almost running point. Also seen it was $28 a spray can at   https://www.farmshopstore.com/search.php?search_query=colorback&x=4&y=5
Edited by chaskaduo - 22 Jul 2019 at 3:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 3:32pm
Well that just sounds like a regular clear-coat then.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 11:33pm
say what you want but there never will be a replacment for lead base paint that last 75 years and just needs to be kept waxed ocassonaly
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2019 at 9:13am
Agreed!
This page was generated in 0.118 seconds.
