Coggonobrien's D15 Series III
 Post Reply Post Reply Page  <1 234
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 11:58am
Coggon
Have you had an opportunity to use the R/H 3 Hydraulic Levers on your Ser.III
while working outdoors in this extreme cold and wearing a pair of insulated mitts ?
I think you will find it is a bit awkward.
I did a similar revision to my D-12 Ser.III for the 2 R/H Valves.
I mounted a Meyers 7' Snow Blade for winter Snow Plowing.
The shorter inner lever is for Hydraulic Angle, longer outer lever for raise, lower.
Both valve levers are similar to yours, close together, point straight up.
It is a royal pain to use the inner hydraulic angle lever on a repetitive basis.
I angle plow to only one side of my driveway, so I have to change the angle from right to left and vise versa at the end of each pass.
Wearing a pair of insulated mitts, it's rather difficult.
I need to rework these levers.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 10:46pm
The custom live hydraulic system has been thru the summers of 2017-18-19 and 2020. It has never once failed to prime, which was my only concern with the pump mounted up as high as it is. It has worked well with no issues and makes the tractor very universal with modern hydraulics. Now maybe someday we can fabricate a real nice/heavy Category #2 three-point hitch that can easily be converted back to snap-coupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2021 at 10:16am
Tom,
I wish I had half your mechanical/fabricating skills! Well done!
Pastor Mike
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2021 at 10:47am
G,
Tractor doesn't do much during the winter. The hydraulics are used for a deere barge box and a heston 1091 haybine.
The Dr is right, after tires are done I need to fabricate a 3pt adapter similar to his.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2021 at 3:49pm
Hell, I would just screw on a 2" extension onto the middle lever and be done with it. That should make it easier to find with mittens on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2021 at 11:30am
I won't be changing or modifying them. If it was a concern I would careful bend them to spread them. As they are now I can run them just fine.
Edited by coggonobrien - 19 Feb 2021 at 11:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 11:25am
Slow progress
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 11:53am
Looking good. Yes progress can be slow. Are rims new? Fits 16.9-28?
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 12:42pm
Rims are new from wold. 15" wide for 16.9x26
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 12:49pm
Mounted, ready for a drive an retorque. 59.75 center to center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 2:16pm
Strokendiesel002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 3:29pm
Looking sharp!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2021 at 8:55am
Like!
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2021 at 4:44am
Looks like a great project!! Well done!!
Andrew Gubbels
Gubbels Restoration
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 5:13pm
Eight years ago this week, the series 3 D-15 hydraulic system project began. Not one problem yet.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 7:08pm
Awesome!
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 7:12pm
Should probably get around to fixing the internal oil leak and then painting it one of these years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 7:45pm
I'd say that was a job well done Dave and Doc!!  I started reading this article and said wait a minute, this is from 2017!! Then I continued reading.....  LOL!  Love them lazer cut brackets man. They came out sweeeet!  Hard to believe 8 years passed already! Damn! I guess it passed the test!   Wink
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 7:53pm
Thanks Steve, it's made quite a bit of hay for me over the years. It's earned a paint job if I have have time to do it. I'd still love a set of late series 2 brake pedals with the good lock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 9:01pm
Not one problem yet. That is pretty darn nice!
Mike Townsley
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 6:26pm
Like this post - exceptional work and very helpful to see how a AC D15 can be modified and improved!  Keep up the good work!!! ~ Orangeman
