Cockshutt 50 project - Buda 273
Ngrant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Topic: Cockshutt 50 project - Buda 273
    Posted: 12 Nov 2014 at 5:41pm
I have taken over a basket case Cockshutt 50 with the Buda 273 engine. I am looking at what I hope is a g262 Allis Engine. I think it may have 2 oil filters on it. Is it possible to be a 262 with 2 oil filters or does that automatically make it a G230? It is a Gleaner engine I am told.
The Cockshutt 40 I repaired last year is now running well. I love the sound of those Buda Allis 6 cylinders!!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2014 at 6:07pm
Post a shot of the left side please.The core plugs on the right side are not used in the Allis engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2014 at 8:07pm
Don, that is original 273 engine in it. It needs a repair sleeve. The Allis Gleaner engine I have not got it home yet. If it is a 262, I will use it as is. If not, I will use the crankshaft plus other parts.
Regards
Neil
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2014 at 9:43pm
I think the 273 used a 230 AC crank. The 262 will put the pistons to hi.
  Don't think a 262 ever had two oil filters. WD45D and 301D used two.  MACK
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2014 at 5:31am
Have someone counter bore your cylinders and put in a sleeve if cylinder wall is too damaged. The 273 is the best blocks because they do not have to worry about sleeves dropping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2014 at 9:11am
I think Lester is spot on, if your 273 block is not broken I'd bore it out and install dry sleeves to get her back to the stock bore. Like Mack said the 262 crank will not work without a lot of piston rework.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2014 at 10:33am
I think I will put in one repair sleeve in the one cracked cylinder wall if the Allis engine is a G230 or a B230 and use its crankshaft as it is supposed to have been recently overhauled. It should fit I would think?? I have some 50 diesel piston I will use when I get them out of the seized 50 diesel block I have. If the Allis is a 262, I will use the whole engine and shelve the 273 block for future use.
Thanks for the replies.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2014 at 5:44pm
I see the basis of a d19d puller, but we will save that for another spot on the forum
1968 D15D,1962 D19D
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2014 at 7:22pm
I remember some talk that a 262 crank in a 273 block will give you 292 (3) cu.in.
Guy was running a WD-45 diesel puller with that combo. Said that 273 blocks were gold and hard to find. A-C built 273 diesel marine and genset engines. I saw one with an inline injection pump.
Edited by Calvin Schmidt - 13 Nov 2014 at 7:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2014 at 8:13pm
Thanks for all the input. I will need to wait a couple of weeks to get the gleaner engine home and see what I have. The differences in the 262 and the 230 with the different stroke - was that taken up in the piston compression height or the rod length if the block is indeed the same part number? If it is the pistons, I suppose machining 1/8" of the diesel pistons would make the 262 crank and camshaft combo work for 291 or so cubes - all that power to drive around the back yard!!
Here is a picture of the 40 complete and the 35L I have also.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2014 at 9:30pm
The cam shaft will be a problem with the 262 crank. There will have to be flat places ground in 230 cam for rod bolts to clear.    MACK
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2014 at 12:05am
I used to have a Black Hawk 40 gas, overhauled the motor and sold it.  Always wondered if a Chalmers 301 could have been shoehorned in there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2014 at 12:24pm
Thanks for the input guys. When I get it all together I may have a 273 block I wiould sell, I should know better in the new year as I gather up the pieces Waiting to pick up the gleaner engine in a couple of weeks Fingers crossed that it is a 262 and runs well, but time will tell.
Regards
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2014 at 3:04pm
My brother was going to install a Gleaner 262 in a Cockshutt 40 years ago for tractor pulling but soon lost interest in both. You will have to use the front cover from the 273 on the 262 for mounting and then there are dozens of little things to deal with.  Good Luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2014 at 7:59pm
Thanks very much. Here is the link to the guidelines, which I would guess would work in reverse to install a Ccckshutt Buda engine like a 40 or 50 into an Allis.
https://onedrive.live.com/view.aspx?resid=A1DD97C33B89181A!4039&ithint=file%2cpdf&app=WordPdf&authkey=!APfel1QkOTnDDd0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2014 at 11:21am
I am going to pick up the Gleaner engine on Sunday. Is there a part number/code or anything which identifies it as a 230 or a 262 I will be able to see on the engine? Anything else I should watch for?
Regards
Neil
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2014 at 9:12pm
From my past experience the 230 will have the water pump on the head mounted with one 1/2 capscew and a 262 will have the water pump on the block with four 3/8 capscrews... Also a 230 uses a bypass oil filter whereas a 262 will have a full flow...
Edited by Travis(NE) - 20 Nov 2014 at 9:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2014 at 9:22pm
On the riveted engine tag it will say G-230 or G-262. Both of these engines are probably new enough to have the water pump on the block and full-flow oiling system. The G-230 will come from the model A or A2 combines and the G262 will come from the model C or C2 or old F combine.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 6:31am
Old A had water pump on head, later A and A2 had water pump on block.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 11:35am
I wonder if the b series had the water pump in the head and all the G series had it in the block? Sounds like the G262 was built during and after the G230 was discontinued? Was there a G230 full flow made at all? is there an outside tell tale difference to signify a full flow model? The G230 would be about similar power to a 40 Cockshutt with the B230 I would guess.
Thanks
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 2:05pm
All the B230 combine engines had the water pump in the head with the by-pass oil system.
All the G-230's and G-262's combine engines had the water pump in the block.
All the G-230's and all the G-262's combine engines had the full flow oil system.
Please post a shot or two of your G-262 combine engine when you get it home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 3:10pm
Thanks very much Don. I will post some pictures for sure. Was there ever a B series 230 used in a Gleaner would you know?
Regards
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 3:13pm
I see you already answered me Don. Sorry. Did the B series combine engines have a double oil filter and or the later large manifold allis used?
Regards
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2014 at 3:31pm
Regards
Neil
 The first B-230 gas engines had one canister oil filter with two external oil lines and had a smaller manifold, some of them had a one piece in/ex manifold too. I have some of old combine B-230 engine parts laying in the back of parts trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2014 at 11:55am
Hi Don. I got it home now and it is on my trailer yet. Here are a couple of pictures of it. It has no tag on it and no date code either that I can see. No plugs on the rh side or even marks like the b230 had where they could and maybe should have put frost plugs. The right side is all smooth. I have a picture of a G262 looking similar while a picture I have of the G230 looks like the B230 on the right side, so I am hoping it is a 262 - any thoughts on if it is?
Thanks for your help. My first thing I will do is take the compression after I put a little oil down the cylinders and then work on getting it running. It has been as few years since it ran I think.
Regards
Neil
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2014 at 9:04pm
I've been working on a coop e4 swap to allis g262. Google cockshutt 40 pulling. If you find a pdf from the antique tractor pull guide. The detailed instructions are on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2014 at 9:25pm
That's a G-262 with that big Bendix carburetor on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2014 at 9:05am
Yes thanks, I have read through that. It is written by a few Cockshutt gurus so I know it is going to work.
Regards
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2014 at 9:10am
That is music to my ears. I should be about the same HP at 1650 rpm as the 273 with the higher compression of the 262 to make up the 11 cu inch. When I do the conversion, I will have the oil pan off so I will know for sure. I just need to work through that little detail of getting it running first!!! It is supposed to run though and I can't imagine it being stored away for these years if it was not in decent condition. Murphy's law does play a role in these things though and it seems sometimes he was an optimist.
Thanks
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ngrant Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2014 at 9:01pm
I took the compression tonight. Some valves can't be closing.
130, 30, 15, 60, 50, 40. Number 1 got my hopes up!
Next is to take the valve cover off and see if any valves are stuck open.
Neil
