Clutch |
Stoges ![]() Bronze Level ![]() ![]() Joined: 27 Apr 2024 Location: Erie Pa. Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Jul 2025 at 2:15pm |
Pulling in 6000# class with a WD my clutch started to slip, not knowing which one it was. The motor clutch is heavy duty and new last year. The pto clutch snaps in like it should. I don’t know which to adjust, I know I can take shims from the pto clutch but have no idea how to adjust the motor clutch. Any advice would be appreciated. Thanks Bill
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3803 |
no adjustment in motor clutch. can upgrade to 9 spring pressure plate and use a 4 or 6 button disk for better holding power
Edited by CAL(KS) - 21 hours 24 minutes ago at 3:17pm |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4982 |
6,000 lbs. class is very heavy for a WD. It might be a good thing the clutch slipped before you damaged something in the drivetrain.
Edited by WF owner - 17 hours 48 minutes ago at 6:53pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21746 |
I pulled 7500 lbs with my 100+ HP D-17 and 18.4 x 38 cut tires a few times one summer. Eventually took a tooth off the right bull gear, not damaging the upper pinion gear. Those 7500 lb days then came to an end.
