Clutch trouble.
Message Reverse Sort Order
tim 1938 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tim 1938 Quote  Post ReplyReply Direct Link To This Post Topic: Clutch trouble.
    Posted: 01 Jan 2012 at 8:50pm
See that is the trouble I have the back wheels off and the back end up on stands
Post Options Post Options   Thanks (0) Thanks(0)   Quote tim 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 8:45pm
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 5:26pm
Tim will the tractor roll while in neutral? It sounds like it may be stuck in gear but we need a little more info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tim 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 5:20pm
I run into some trouble on my 1940 model B  if the clutch  is not engages I can't crack it over  but if I set the clutch with the little engage plate I can crank it over  I have not done anything to the forks ( have not even taken it apart yet)   any ideas  thanks
This page was generated in 0.242 seconds.
