clutch replacement F8000 w/13 speed
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: clutch replacement F8000 w/13 speed
    Posted: 13 Aug 2018 at 10:32am
What's the best way to go about this? Remove that big ol Eaton 13 speed (we haven't got a good trans jack) or pull motor? We need to replace the clutch.
Thanks
Leon B Mo
Edited by Leon B MO - 13 Aug 2018 at 10:32am
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 11:02am
Pull the transmission and rent a good transmission jack if you were closer you could borrow mine. Take your time setting jack up and put a good size ratchet strap around it. Taking it out is easy putting it back everything has to be dead on and get a good clutch line up shaft. I use an old input shaft to line everything up.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 3:21pm
I made a makeshift transmission jack out of my floor jack by welding a round pin the size of pin on the cup of my floor jack to a 1/4" steel plate about 1' square. I would put the plate on the floor jack in place of the cup any time that I needed to remove or install a transmission. Not as versatile as a true transmission jack but it did the job.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 3:24pm
I ditto Red Bank.  A trans jack with a tie down on it makes it fairly easy, if you have a level floor (concrete) to work on. An alignment bolt on the bell housing helps get it in place easier. I find the bigger trucks easier to work on then small ones as there is more space under and around the parts.  Plus the parts are way to heavy for a guy to think he can just manhandle it into place....
Allis Express participant
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 4:33pm
that is a big and heavy transmission.. I wouldn't trust a converted floor jack,, go borrow, steal or buy you a TRANSMISSION jack heavy enough to handle the weight,,, or farm it out to a truck shop....
put in new throw out brg shaft and bushings while its apart....
and what John said...
Edited by Michael V (NM) - 13 Aug 2018 at 4:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2018 at 6:52am
Got a bid from a local truck repair shop, $1700 was the estimate. We might just let them do it. I have used a floor jack for smaller trans and didn't like it. I've done clutch work on other similar trucks but not with a big ol 13 speed
Thanks for the input.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2018 at 4:25pm
I think id spend the 1700, that's cheap enough
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 11:03pm
Does it have a double disk in it. I had one and it rattled like the old 3208cat with a double disk. Sorta a pain in the rear gear to change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 7:20am
I don't know for sure what kind of clutch it has. Since I have plenty to do to keep me busy, I think I'll let the truck shop do this one.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 2:04pm
some things are best left to the experts... while 1700 may be  alot of coins...you GET a WARRANTY on the work done ! AND it's usually done in a couple days AND you don't have any busted fingers, mashed toes, or funerals to go to....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 2:38pm
Dependent on the year will either be a 14" two plate or a 15" both spicer. You will need a trans jack capable of handling almost a thousand pounds with oil still in the trans and if has PTO that ma need come off. There are nuances to these such as replacing and aligning the center plate dogs on a 14" having the arm strength to hang a 15" loaded and also having a 2" input shaft for aligning the plates. If has a 'Button' clutch those have to be face to face when installed or will chatter to hell and back possibly even slip under severe load.
Under $2000 at a shop is cheap insurance. May also need a input shaft or flywheel reface, TRUST THE MECHANIC as to his suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 2:40pm
Who quoted Leon? May know them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 3:24pm
Waco Truck Service right here in Moscow Mills is where I got the quote.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 3:38pm
Now the next question. I have a half inch of free board left on the clutch pedal with no more adjustment. Will it make it through the fall? Lots of short trips from field to bins or farm to farm no more than 5 miles. And my 18 year old son is only on his second year driving it field to bin, possibly a little highway time this year.
Leon B
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 5:30pm
Since only time the clutch is used is starting or stopping - if it isn't slipping when starting in motion it should . The trany should shift without the clutch once moving .
  I changed a lot of them on COE Petes with 8V-71 power and 13 Speed but had access to a Blackhawk heavy jack from shop up the road from me .
On my old White had the 5 speed main with single disc clutch and bought a transmission jack for about $400 that handled most - did a couple 13 speeds with it but not as stable as the large jacks that are made for HEAVY  truck units .
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2018 at 2:35pm
Might consider fixing BEFORE you need it.Nothing like breakdown when your using it.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 10:39am
unless you intend on using a trans jack rated for a roadranger then dont even mess with it because  bad things will happen  with proper jack it isnot so bad
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 11:52am
That would be my thought, too!
at least that way you get to plan the outage
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 2:33pm
The only time it will fail will be half stuck in a soft spot in the field with a full load on when you need it most. Get a clutch in it now and be done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 4:33pm
DMiller, that's exactly what I told Dad, if it gets wet....and right now, that seems a long shot, it would be harder on the ol gal. It really hasn't gotten much worse in the last 3 years, so I think we are going to run it this fall and send it in after the 1st of the year. That ol 13 speed, if you start out in low, loaded, you can let the clutch out without touching the fuel pedal. I am not going to do it myself, I'll let the experts handle this one when the time comes.
Thanks for all the  input.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 6:35pm
I know you said you have 1/2 of freeplay at the pedal and no more adjustment left. Have you been adjusted freeplay with the linkage or at the pressure plate? And when you look up through the inspection access how far from the clutch brake is the throwout bearing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2018 at 7:42am
At the linkage. I wasn't aware it could be adjusted at the pressure plate. I'll have a look at the gap when I get a chance.
Leon B
Edited by Leon B MO - 20 Aug 2018 at 7:43am
