Clutch plate replacement 7050 PD.
notime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Topic: Clutch plate replacement 7050 PD.
    Posted: 15 Nov 2022 at 2:05pm
Where is the best place to get new clutch’s for a 7050 power director. I understand Kevlar clutches are available. Has anyone used them? Any comments or recommendations?
Thanks
Edited by notime - 15 Nov 2022 at 4:03pm
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 6:52pm
Your local dealer...where are you located?
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 8:24pm
Don't know how you plan to use it but  I resealed the PD in my 8070 @5000 hrs and the friction plates were not visably worn. I would think with normal use and maintainance factory parts would last as long as you. Nothing wrong with Kevlar but doubt it's worth it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 6:24am
I’m in Canada. Factory clutches are $270 each x 4 just for low range, x6 for both ranges. My PD was slipping and I need to replace low range clutches. I found a dealer in Edmonton who could supply the Kevlar clutches for 140 I believe. That is the obvious choice if they are ok, but I know absolutely nothing about them. I have considered buying used ones as well but I’ve gone to a lot of work to do the split, I may as well do it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 6:29am
In answer to your question Ron I’m North of Saskatoon in Saskatchewan,
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 9:01am
Are your plates warped or worn out.                      MACK
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 10:02am
  I use the Kevlar plates in my 7040 puller, two seasons and they work great!! The stock plates would warp constantly, talked to the engineer at Tribco he guaranteed their plates would not warp.
  I was told by AGCO dealer they would engage a little harder but I cant tell since my clutch is highly modified.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 10:35am
The "kevlar" covers the driving discs, right ??     Are Tribco's separator "plates" any different ?? maybe thicker?  A-C used thicker separator plates for low range on some applications and they don't warp as easily as the thinner separator plates.  Or does the kevlar material create less heat when being slipped ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 11:54am
  Yes,they glue the kevlar on somehow, they are no thicker but they use the best steel available and I believe they do create less heat.
  On my puller the stock plates would only warp after they would start to transfer the bronze onto the separator plates, it would not be much material and it would be two to three in the middle of the pack.
  Mainly the clutch plates warped but every blue moon a separator plate would warp, I have all thick separator plates installed.
  I suggested maybe using spring steel because of its good memory but the engineer told me dont worry, they wont warp.    Also told me a JD with good more hp is using them successfully.
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 4:08pm
At least two of my clutches are warped and burnt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 4:30pm
So where did you buy the Kevlar clutches?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 4:46pm
After a failure like that, clutch pressure needs to be verified....195 to 205 psi minimum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 5:04pm
I just found Tribco on line and sent them an inquiry. Does anyone know if they sell direct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 5:06pm
Good point, thanks
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 8:55pm
I would not use used plates. If you're in there do it right. I know a guy that used used separator plates that I checked on a flat piece of 1in plate that you couldn't feel it wobel. After he put new in it wouldn't drag. This was on a power shift 8050.
Edited by CORLEWFARM - 18 Nov 2022 at 9:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 9:36am
  They did for me here in the states, I just called them and ordered.
This page was generated in 0.046 seconds.
