Clutch kit for AC220
Meavy_Hetal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meavy_Hetal Quote  Post ReplyReply Direct Link To This Post Topic: Clutch kit for AC220
    Posted: 19 Feb 2026 at 2:33am
Hi there,
I am new here and looking for a bit of advice.
Became a 220 owner last summer in England, UK after bidding on it at auction. I have been told by the previous owner it is the only one in the country. This has meant parts are having to come from the US.
I have reconditioned the starter motor and have a ring gear on its way over from the States as they weren't always meshing and a bit chewed in places. I think it is best I do the clutch while split.
Is there anyone here that would be able to send a rebuilt clutch over? I think I saw Rick mentioned in a thread and warnings of the chinese reproductions. There is a clutch kit on Reliable Aftermarket Parts but it costs over $900 delivered.
Any help greatly appreciated. Thanks
Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2026 at 10:14am
Try:   Parts ASAP    Item:   202034 clutch kit       $510 for a reman
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2026 at 10:16am
I suggest you pull clutch apart and assess it's condition before automatically just replacing it. It cold be just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meavy_Hetal Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2026 at 11:06am
Thanks for the replies and the link to the parts.
That had been my intention to assess when we have a look others have said while it's split may as well do the clutch. Having said that it's not like it's on any heavy draft work these days!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2026 at 11:33am
At a minimum, if you are going to split it for some reason, my rules are new rear seal and sleeve, both new clutch shaft/PTO shaft seals, and a new throw out and pilot bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meavy_Hetal Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 5:46am
Thanks very much for the helpful advice.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 7:14am
For $510 I sure wouldn't be putting any used clutch parts back in the tractor,also X2 on what doc said.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 7:56am
  Only 220 in England??  Do you know the origin story??
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2026 at 8:09am
Awesome, did it originally or aftermarket have a cab ?  Worth the investment to do it right.
This page was generated in 0.313 seconds.
