Clutch Carnage
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Clutch Carnage
    Posted: 17 Aug 2025 at 4:52pm
Self inflicted, of course Cry
I just hate when I do dumb things Embarrassed
We recently got the derelict Model C assembled enough to try to see if it would make some noise. The B-125 combine engine was stuck so we pulled the head and pan, got it freed up and did a basic valve job, we did not pull the pistons nor did we remove any bearing caps.
Hand cranking resulted in no joy, and hand cranking to check compression showed VERY low compression, less than 45 psi on cylinders #1 & #4, less than 10 psi on #2 & #3.
We then connected the derelict Model C to my other Model C via the flat belt pulleys, gave it a whirl and it fired right up!
I immediately shoved the clutch forward to disconnect the tractors, trouble is, there was excessive looseness in the clutch pedal and the pedal slipped right past the physical stop on the torque tube, thus allowing the clutch rod to slam forward into the clutch fingers, instantly breaking them off of the pressure plate.
Besides the obvious looseness in the clutch pedal, which I have since fixed by drilling out the holes and installing an oversize clutch pedal shaft, the clutch operating rod was too long, a previous owner having lengthened it by welding a bolt in it. I had to cut off about 5/8" to get it back to the correct length.
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 5:59pm
Don't you just love life lessons....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 7:07pm
Yup! Smile
I am probably the only person on the planet to have ever put this particular combination of errors together to create this problem in the past 80 years Embarrassed
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 7:55pm
That is the best story that we have heard here recently! Will make for some good laughs for your next shop get together! Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 8:29pm
Normally the comments are "YEP... Been there Done that"........ but this time i think YOU got a Cherry !!  Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 9:24pm
Yup Tongue
On Page B-C - 30 of the shop manual it reads "Usually one or two threads extend through the yoke screw when properly adjusted. Make sure the clutch pedal strikes stop on side of torque tube."
My 14 year old Grandson is my partner in grime on these projects; I told him that sometimes it is good to know how NOT to do things Tongue
