Clutch adjustment for '44 B
steigerbro24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Topic: Clutch adjustment for '44 B
    Posted: 24 May 2011 at 5:18pm
I want to tighten the clutch on my 1944 model B but I don't really know how to. I have a copy of the owners manuel but it tells me to remove the cover on the lower end of the clutch housing. Then turn the adjusting screws until I have 1/4 clearance. I looked and I can't find the screws and I don't know what the manuel is  talking about.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 6:46pm
You go through the hole in the bottom of the clutch housing.  Let me see if I can remember back some almost 40 years.  There are three clutch fingers.  They are pushed forward by a "throw out bearing".  The 1/4" clearance is between the throw out bearing and the clutch fingers.  It can be adjusted by adjustment screws on the fingers.  There is a lock nut that needs to be loosened.  Then the adjustment can be made and the lock nots re-tightened.  Repeat till all three are set.  There is also a small adjustment that can be made on the clutch rod.  To adjust the clutch rod is removed from the clutch pedal and turned to adjust.  We very seldom used that adjustment but adjusted the clutch with the fingers.
Hope this is some help.  Again, this is from memory so if there are others on the site and I am in error they can comment here.
Take good care of my favorate.
Good Luck!
Bill Long
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 9:31pm
Does the clutch slip? If it does, is the petal at the end of it's travel?
If it is slipping, and the petal has play, you need a new clutch.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 10:09pm
My clutch doesn't slip but it does have alot of play and I want to get rid of that and tighten it up Thanks for the help
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 11:22pm
Hi,
This may give you an idea-you can see the 3 levers and adjustment bolts your manual is talking about.  You will have to loosen the nut that hold the adjustment bolt, then turn the bolt to give you the proper clearance, then retighten the nut.
A tight fit if you have big hands, but can be done.  All 3 levers need to have the same clearance.
Thanks
cmsmoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 6:12am
The clutch fingers are adjusted to be 1-13/16" from the clutch disc. Once this is accomplished, the 1/4" between the throw out bearing and the fingers is done by removing the cotter pin that holds the clutch rod to the pedal and rotating the rod to adjust. The rod is threaded at the end where it attaches to the throw out bearing inside the bell housing. The fingers are usually adjusted when a new clutch disc is installed and the tractor is split. I would imagine it would last the lifetime of the disc as long as free play has been maintained between the throw out bearing and the fingers. When the disc wears the fingers move toward the throw out bearing. It will be hard to do put together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 9:52am
The picture helped me find what Im looking for thanks for it and all the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:06am
It sounds to me like you want to adjust the free travel of the pedal, which has nothing to do with adjusting the fingers on the clutch.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 12:38pm
WC7610, I see you have a 9" clutch, is this a B? Or a D10/12.
I'm in the Wentzville area also!
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 1:15pm
wbecker,  it is from an RC.
I'm in Peine Ridge Subdivision-where are you?
Thanks
