Cloudy OIl again Please Advise ..Thanks
Ray54 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2024 at 11:58am
Ed you surely are disserving of some award, Wink unless your tractor never leaves the shed. I always feel lucky if don't have to find a new exhaust cover every time I use a tractor anymore.
I am now down to hobby farming, so maybe I could keep a flapper on top of a exhaust. But to many trees in my life to not get them ripped off if really used.
Albertfitch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertfitch Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2024 at 4:09pm
Hi Steve my girls been on the bottle now for three days  has had her  head screwed down 2 lbs, tighter , run around those days for 2-3 hours  up hills and bush wacking  and thanks to your advice and the help of so many other generous  forum members  her oil is staying clear . As a note , if helpful, to others . After the first days  run  I let her cool down completely , the dip stick looked good  ( thanked the Lord ) and took off the valve cover , ready to follow the advice of Bossman and the others ..RETOUQUE !!!  my knees buckled when I saw streaks of cloudy oil , small but numerous ,on the inside of the cover near the push roods . Yet the dipstick oil was crystal clear .  I kept working her and checking  and the dip stayed happy. It then dawned on me that there must have been tiny amounts of the original cloudy oil  clinging  about  in the block , that did not drain out after a week of the drain plug removed .  Anyway ,again so many thanks for your  guidance and patience .."WE " are all better now  and all because of You; Albert and Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2024 at 4:22pm
Hopefully this will be a LONG TERM FIX and you wil be good for a few years... I had a truck engine that was BAD BAD for this and i had to  "Redo" once every 18 months.. I have had minor leaks on a couple tractors and the FIX has been good for several years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertfitch Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2024 at 5:25pm
Thanks Ekjdm 14   Yes it was the pressure pump ..you would have laughed to see me even attempt to get it to 2 psi much less hold it for 3 seconds . The plunger seal was so bad it wobbled around in the cylinder  and Advance auto out here in the wild north didn't have a loner. I followed a couple of the alternate approaches  and in the end the oil is holding clear at last and the bullet dodged .  Thank you for taking the time to help me ..your advice was the first step I would have taken  All the best  Albert
