Cleaning Sediment Bowls
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Topic: Cleaning Sediment Bowls
    Posted: 31 Dec 2010 at 10:52pm
Is there a cleaner (carb cleaner or the like) that will remove the outside oxidation of the sediment bowl pot metal, or is the only solution elbow grease and steel wool? I hate to paint it.
Edited by GBACBFan - 31 Dec 2010 at 10:52pm
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 9:40am
Glass beads or replace.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 9:48am
It it was on the tractor when the factory painted, it got painted. If its bare it was installed later. Any treatment that takes off the oxidation will change the shape of the details like mold lines, and probably upset the gasket seating.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 12:14pm
You might try soaking it in one of the aluminum car rim cleaners and an old tooth brush to rub off the oxide ?
Or use a 'dremel' tool.......????
