Cleaning questions
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: Cleaning questions
    Posted: 26 Feb 2012 at 12:08pm
Electrolysis works if you have a little time. It will remove old paint and rust also.
http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
Some say,"I don't have a container big enough" Just dig a hole in the ground or build a wooden box and line with plastic. Lots of old lawn mower blades help:)
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 11:54am
I use kerosene.....mine was sludged when I drained it too. When you prep for paint, wash with either oven cleaner, or comet....neither will affect paint. I always wipe with laquar thinner too.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
kschab92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 11:01am
I pulled the axle out of my wc last night and it is just covered with sludge on the inside. What is a good way to clean this out? My thought was to drain the differential and flush some mineral spirits through the ends of the axle housing a few times. Any other ideas?
Also when I prepare to paint, there is quite a bit of grease that wont come off with the pressure washer. If I scrub what I can off and sandblast, will the sand take off the oil or will it push it into the metal?
