Cleaner E combine engine to WD tractor swap |
Kris5s64
Joined: 11 hours 43 minutes ago Location: 47429 Points: 3 |
Topic: Cleaner E combine engine to WD tractor swapPosted: 11 hours 23 minutes ago at 6:36am |
What modifications &/or adaptations need to be made when swapping a Gleaner E combine engine into a WD Allis tractor?
Doug Acord
Posted: 4 hours 15 minutes ago at 1:44pm |
You will need the front cam Cover off the WD ,to use the WD governor, and will have Drill the Holes in the cover to match to the block. Need a WD style water pump. The front Crank pulley of the WD will need to bored out to fit the E crank also the set screw will need to fill in and move to make the Belt line up to the water pump pulley. If is a full flow oil system the one oil line will need to be reroute and the steering yoke on the side of the tractor will need to shorted to let the oil line pass. Last was the block need to place in the tractor and see it will hit the frame at the governor case it does just grind out the spot on the block to make it fit.
