Chrome piston rings Mix and Match?
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: Chrome piston rings Mix and Match?
    Posted: 17 Feb 2010 at 5:18pm
I am working on an engine that only needs Piston rings for one cylinder. The problem is that the top ring on the three good cylinders is Chrome plated and the new rings for the other cylinder are not. Would I run into any problems using chrome rings on three cylinders and moly rings on the other cylinder. Unless some one has a set with a chrome top ring for one cylinder. The rings I need are 4 1/8 bore.
1st 3/32" chrome
2nd 3/32"
3rd 1/8"
4th 1/4" three piece oil ring with expander
Thanks in advance for any advice or opinions
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
This page was generated in 0.099 seconds.
