Chevy transfer case |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Topic: Chevy transfer casePosted: 10 Mar 2018 at 5:04pm |
I have a question for any GM mechanics. On my 01 suburban, the transfer case is sort of stuck in a neutral position. It won't go into 4 wheel drive or 2 wheel drive. If I hit the button for 2 wheel drive, the light by that button will blink for about 5 seconds, then nothing. If I hit the 4 wheel drive button, light by it does the same thing. Suburban won't move. If I try to put it into park, after trying drive, transmission will grind. The "service wheel drive" message shows up on the message center. There were a few times in the past six months that it didn't want to change from 2 wheel to 4 wheel quite like it should have, and that message showed up then, too. But shutting it off, and starting it back up cleared the message. Is my whole transfer case going to be toast, or is there a shifting solenoid that may be the culprit...? Any advice appreciated, Thanks. Darrel
Jim.ME
Posted: 10 Mar 2018 at 6:54pm |
I had to change the switch unit in my 2007 2500. It would blink similar to what you describe when I tried to go into 4 wheel drive low. It would still go in two wheel drive and 4 wheel high. Parts guys here said the switch failing is a common problem.
Dakota Dave
Posted: 10 Mar 2018 at 6:55pm |
Most likely its the shifting encoder its on the Left side of the transfer case has three bolts and one electric connector. on some vehicals you need to take the front drive shaft off to get one of the bolts. the control module the part in the dash is the only other part in the system. its cheep and easy to change the encoder is more expensive and you need to get under it to replace it. I did my wifes just pushing it up on ramps with the tractor. it took a couple hours.
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 10 Mar 2018 at 9:24pm |
X2 on the switch.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 10 Mar 2018 at 9:31pm |
a good scaner wil show you the voltages in and out of the endcoder motor and also the shift state if it checks out its probley the dash switch . we just done a 2003 avalanche about three weeks ago that the guy said it whent into low going down the hiway but it really didnt . but i did have it get stuck into nuetral in front of the shop our fix was the dash switch
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1124 |
Posted: 11 Mar 2018 at 6:23am |
Try dash switch. It's cheaper and easier!
darrel in ND
Posted: 11 Mar 2018 at 7:15am |
Thanks for all of the replies, guys. I am breathing a little easier now that I reletivly sure that it's not something that's going to require a whole transfer case rebuild or replace. Darrel
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 11 Mar 2018 at 11:16am |
Neighbors 4x4 chev - dealer repair $700 , modual, hoses , tear into fron axle and transfer case + replace switch
Friend who owns transmission shop - replace switch on customers 4x4 - $70 Mine replace switch $34 ![]() Edited by Coke-in-MN - 11 Mar 2018 at 11:21am |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 11 Mar 2018 at 11:26am |
With a 2004 2500HD, I was getting a "service 4WD" message on the instrument panel, when trying to go to low, 4wd, 2wd, along with AC, blower controls, and others, 5 electrical items getting power from Ignition switch.
A large diagnostic bill with $35 switch got me running. Wish this information were released sooner.
Edited by JoeO(CMO) - 11 Mar 2018 at 11:27am |
Coke-in-MN
Posted: 19 Mar 2018 at 7:39pm |
the info has been on here couple years or longer - mine went bad around 2007 on my 2000 GMC - but then the transfer case itself went out at 3,000 miles - seems there were a bunch from the factory they set up wrong and so I got a replacement unit back then - 4 days down while they shipped one in - problem was it went out while i was plowing
Gordy
Posted: 19 Mar 2018 at 8:01pm |
Dash switch on my 01 Silverado was bad I found it had bad solder connections on some of the pins in the circuit board inspect it with a magnifying glass and you will see hairline cracks re solder them and works like a new one.
“If you can't explain it simply, you don't understand it well enough”
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5175 |
Posted: 20 Mar 2018 at 3:44pm |
My 06 did something similar and mine was the encoder. I bought one from a junk yard for $200 instead of $400 or $600 (don't remember which) and mine has been fine for 3 or 4 years now
alan-nj
Joined: 12 Sep 2009 Location: oxford, nj Points: 847 |
Posted: 21 Mar 2018 at 1:11pm |
Had a 2005 Silverado....not sure if it applies to 01 or not, but a common shifting problem with them was a bad ground. Look for a grounding bolt on the frame rail on the left side approximately under the driver's door. Clean all the connections on it and see what happens.
If ignorance is bliss, than happy days are here again.
Brian Jasper co. Ia
Posted: 21 Mar 2018 at 8:12pm |
Switches were common problems, so were encoder motor sensors. The sensor is quite a bit cheaper than the whole motor assy and are easy to replace.
darrel in ND
Posted: 21 Mar 2018 at 9:44pm |
I'm getting a little nervous. I took this burb into the local service station/repair shop over a week ago. Told him what was wrong with it, and told him that I was relatively certain it wasn't going to need a complete transfer case. I don't see it outside in the "done" row yet. Darrel
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2307 |
Posted: 21 Mar 2018 at 10:45pm |
If you need a new T case.Transfer Case Unlimited 800-683-7623 They will exchange yours for around $1200 I have been very happy with mine. They install new front and rear housings with the pump upgrade. ETC ...... Good Quality T Case ... with warranty.
Do NOT get yours rebuilt. GM OEM case has several inherent issues, especially after they get a few miles on it. IMO |
