Chevy tire sensor |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3074 |
Topic: Chevy tire sensorPosted: 05 Nov 2025 at 9:51am |
Daughter had to have hers replaced and now one of ours is messed up. She was told to replace all four. Does that sound smart or just an up sell? Thanks
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24781 |
Posted: 05 Nov 2025 at 10:07am |
well if they're all from the same batch, it does make sense. car's only out of commission ONCE not 4 times !!
ACinSC
Posted: 05 Nov 2025 at 11:39am |
Thanks Jay, makes sense.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34415 |
Posted: 05 Nov 2025 at 12:45pm |
Is as simple as valve Stem replacement HOWEVER will have to find tire shop with correct units then reprogram ECM to see them. 2010 Impala, been thru TWO replacement Sets.
ACinSC
Posted: 05 Nov 2025 at 12:55pm |
Thanks Dave I was wondering where the sensor is
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 553 |
Posted: 05 Nov 2025 at 2:30pm |
I'm a believer, saved me a tire while on the interstate. A tire started losing pressure fast, managed to limp it off the hwy before totally flat. Getting the wheel of was another story, seized on the hub and had to get a guy with a BFH to knock it loose. Tires had been rotated-at least I was told they were? Many tire shops want to replace sensors when new tires are installed.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12250 |
Posted: 05 Nov 2025 at 3:06pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42045 |
Posted: 05 Nov 2025 at 3:09pm |
You can get them aftermarket a lot cheaper than at dealer or tire shop
Friend just ordered set from Amazon - 4 units - 1 bad - ordered another batch 4 good returned first set - bought new tires and had 4 new ones put in -
Units should reprogram themselves within a few miles , on my Sebring had 3 bad stems over 3 years - first 2 replaced under warranty - next one Dealer wanted $90 to replace - tire shop aftermarket was $40 installed - rebalance tire - reprogramed itself within a mile |
Coke-in-MN
Posted: 05 Nov 2025 at 3:12pm |
WALMART had a set of 4 for $28 to fit my one pickup - Sure lot of places sell them online .
Joined: 11 Sep 2009 Location: illinois Points: 88605 |
Posted: 05 Nov 2025 at 3:14pm |
WE have a 2010 EDGE and a 2013 F150 and both have the original sensors... 10- 25 years is suppose to be the "limit"...battery eventually dies.... Like Dave said, they are inside the tire , connected to the valve stem..
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6504 |
Posted: 17 hours 60 minutes ago at 6:36am |
[QUOTE=Tbone95] Hmmm, questions….why is a cop car equipped with a pick ax, and what am I supposed to do with it?
He really wanted to be a firefighter but had to settle for being a law enforcement officer 😜. Shortly after I changed to P rated tires on my 2013 F150 tire light came on but when I went back to LT tires it went off. Guessing the sensors didn’t like the change in the amount of pressure.
ACinSC
Posted: 17 hours 4 minutes ago at 7:32am |
Just checked and our light's not on . Daughter paid $140 to have 2 sensors replaced yesterday. I'm sure our light will come back on. Thanks
DMiller
Posted: 9 hours 27 minutes ago at 3:09pm |
Have to have some way to dig the Hole, for the Bodies.
