Check your bolts!
DSeries4 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Check your bolts!
    Posted: 20 Oct 2025 at 3:16pm
I took a couple of lift hooks off one of my snap coupler plows.  Good thing I did - not much left of some of those bolts!  I decided to take all my other ones off to check as well.  They are all getting replaced.  I would hate to see if one of those bolts failed while going down the road.  Also switched out the bent over nails in the pins for proper roll pins.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2025 at 5:03pm
Good catch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2025 at 7:56pm
Thought they had a bushing inside link that bolt pinched down on and it took the wear?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 5:38am
I've seen my share of carriage bolts just like that. Good idea to just replace them, especially on a plow.
I love those bent over nails too!
Steve, they do have a bushing but it's the bolt that seems to wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 3:30pm
Yes, they do have bushings.  They looked far better than the bolts.  I did replace a few while I was changing the bolts though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 5:28pm
I would imagine those OEM bolts have three hash marks on the head, making them grade #5.  Many carriage bolts have no marks making them grade #2.   Just a note of caution when installing new hardware.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 26 minutes ago at 6:35am
I should have mentioned that I buy grade 5 carriage bolts for such matters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 26 minutes ago at 8:35am
"Check your bolts" !!........and your nuts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 49 minutes ago at 7:12pm
Especially your nuts!  You don't want anything to happen to them either Myron!  Wink
Steve@B&B
