check valve I-600 box blade
bgabriel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bgabriel Quote  Post ReplyReply Direct Link To This Post Topic: check valve I-600 box blade
    Posted: 19 Sep 2016 at 3:53pm
Does anyone know if the AC I-600 has a check valve on the hydraulics for the rear box blade? If so, might they have a photo or a location of where on the tractor it might be located? Any thoughts on where replacement seals could be obtained for this check valve?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 4:55pm
What makes you think it is specifically the check valve you need to address? If the hydraulics bleed down it can be the seals in the hydraulic cylinder that need replacing or a leaky hydraulic hose leaking internally. Just suggesting possibilities...
This page was generated in 0.406 seconds.
