Char-Lynn torque generator |
waldersha ![]() Bronze Level ![]() Joined: 30 Sep 2013 Location: Kansas Points: 47 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Aug 2022 at 4:01am |
Putting together my WD45. Have a char-lynn power steering setup, but it has been unhooked. It is a 100 series torque generator, I believe 101. Can someone tell me which port is in and which out? I don’t see any indication on the port block or the body itself and don’t want to hook it up backwards.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4067 |
https://www.allischalmers.com/forum/wd45-char-lynn-power-steering_topic171455_page2.html?KW=steering This is a link to the power steering thread I did a couple of years ago. In the second to last picture on the second page you can see the pressure line in the top port. If your torque generator is 'clocked' the same this will work for you.
Thanks for your response. Mine is set up slightly different with the generator on the bottom side of the bracket, but was able to use your pic and get it installed. Much appreciated!
