Char-Lynn power steering |
snorten7020 ![]() Bronze Level ![]() Joined: 10 Aug 2014 Location: W. IA. Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Aug 2024 at 11:55am |
Power steering on wd. Steering wheel violently rotates back and forth. Changed O ring seal on steering wheel side of power steering. Full of red oil. Pump appears to be ok. Any help would be greatly appreciated. TIA
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21841 |
It was OK fine until you changed the Oring ???
It was doing it before O ring change.
Can't say I've ever had one of those do that. I guess I'd be thinking the centering leaf springs may be broken. Can you stop it from doing this by holding the steering wheel in the center of the back and forth ??
No. I can't hold it. The front wheels will turn all the way to the left.
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1278 |
This is a tractor that you have been using for years and it just started this randomly ?
Like I said, never seen one do that. It has to be internal on the top half (input) of the assembly. Maybe a broken leaf (centering) spring ?? Not going to fix itself. Care must be given to reassemble EXACTLY as it was before or the steering wheel will spin like an airplane propeller when you start the engine.
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2458 |
Never worked on one in a farm tractor but rebuilt many in construction equipment. Orbital steering valve is what it is called and support is good for them. They are easy to rebuild on a bench but do install new thrust bearings and washers using only a Char-Lyn rebuild kit.
That's All Folks!
jdeere562 ![]() Bronze Level ![]() Joined: 02 Oct 2023 Location: SW Iowa Points: 43 |
Sounds like something was mis-clocked during assembly.
Sounds like something was misclocked during assembly.
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2677 |
I just replaced the O ring on mine and it's not just an off the shelf O ring. It's a square O ring. I used a factory kit. Spendy for a kit but it works. Won't solve your problem though I don't believe.
Edited by mdm1 - 07 Aug 2024 at 2:35pm |
