Charging 8V battery
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Topic: Charging 8V battery
    Posted: Yesterday at 4:05pm
My friend dropped off an 8V battery out of a 1946 Ford that someone had installed. What is best way to try to charge this? I have several chargers but nothing 8V. I think the battery is no good. I will check voltage of it first and go from there. Thx.
Edited by Ed (Ont) - 22 hours 30 minutes ago at 9:37pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:13pm
You should be able to charge it with a 12-volt charger on the lowest setting, without hurting anything.
Several battery chargers had a single setting for "12-volt low - 6-volt fast charge".
Edited by WF owner - Yesterday at 4:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:19pm
and if you have a volt meter, connect it across the terminals and monitor as the battery is being charged with the 12v charger..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:01pm
Thanks guys! Smile
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 46 minutes ago at 4:21pm
I was just talking to my starter and alternator repair shop a few days ago and got on the subject of 8 volt batteries in 6 volt systems.  In short, they DON'T work!  The maximum output of a 6 volt generator is only 7.2 volts, so the 8 volt battery will never get fully charged, instead it keeps draining.
A 6 volt battery with a 6 volt electrical system that actually WORKS is a far better choice - a good working generator and very thick battery cables.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 41 minutes ago at 6:26pm
Actually, they work well enough that Allis-Chalmers offered it as standard equipment on the W226 Power Units.
It is a simple matter to adjust the Third-Brush type generators to properly charge an 8 Volt battery, my late Father-in-law ran his WD this way for decades with no ill effects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 34 minutes ago at 6:33pm
a 6 volt generator NOT CONNECTED TO A BATTERY, will put out about 14 volts... A 12 v generator NOT CONNECTED TO A BATTERY will put out 28 volts... I have measured that several times....... The BATTERY is the SINK or REGULATOR for the gennerator....  So when you connect a 6v generator to a 6v battery you will get 7.2 volts or so..... Connect that same generator to a 12 volt battery and it will be around 13 volts...
The BATTERY is more or less a REGULATOR of the voltage.... remember the old days when they said "dont pull the battery terminal off when truck is running"  ??... you can blow out the head lights or other equip when the generator voltage SPIKES..
You may not get a lot of CURRENT or AMP output... but you will get a lot of VOLTAGE.
