Char Lynn power steering
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: Char Lynn power steering
    Posted: 05 Dec 2018 at 8:13pm
Does anyone know the proper belt size for a char Lynn unit on a WD45? My belt is very thin and not sure that’s the correct size or if it’s just really worn down. Thanks Michael
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2018 at 9:52pm
It's an A series belt should be 1/2" wide.the generator is a B series belt it should be 5/8" wide. If it's thinner than 1/2" it's wore out and you problem have a slight miss alignment. I know mine dosent run exactly true, I don't have the correct Charlynn bracket, but a rigged one that works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2018 at 10:00pm
Dave, thanks for the information.
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2018 at 10:25pm
when mine broke L used a LINK BELT dident have to remove the lower rad. hose
        KENT
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 8:21am
Michael, this should get ya lined out.#20930 in the illistration and partslist.gives dayton and gates numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 10:53am
Thank you kindly
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 6:26pm
A good stiff belt is great this time of year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2018 at 7:11pm
Yeah, and it has ice in it Lon!
