changing the oil
MFOSTER54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MFOSTER54 Quote  Post ReplyReply Direct Link To This Post Topic: changing the oil
    Posted: 24 Apr 2012 at 9:43pm
When I picked up my CA from a Auction site, I noticed that the oil cap was missing----I had the telephone number of the seller and asked why it was missing, he said it did not have one----it had rained a couple of days prior to the auction and I decided not to crank the CA----I have drained the oil from the oil pan---rainwater had entered the tractor from the missing oil cap----I have used some cheap oil and rinsed the oil tube and oil pan by using air pressure to push the cheap oil to purge the rain water. My question is what oil would a person use for a tractor that has some good amount of wear and hours on it? I have a oil cap from another CA to prevent rain from falling in the oil tube.CryShocked
IF I WAS ANY BETTER I'D BE TWINS.
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 11:28pm
It's hard to beat Rotella 15w-40 for any type of scenario.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 6:11am
I use shell SAE 30 in all of my tractors. (unless diff in manual)
Edited by Josh Day - 25 Apr 2012 at 6:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MFOSTER54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 8:38pm
Went to Wal-Mart and they did not have a bit of 15-40 Rotella---got to thinking about when I was a young squirt---and Grandpa said the thicker the oil the better it is----was Grandpa wrong with a fickle Allis Chalmer Ca?
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 8:54pm
I also use Rotella.  I buy mine at farm supply, but autozone and orielly's also carry it.  No, thicker is not always better.
15-40 is a nice blend and worth finding.  Most 10-40 or 15-40 will be fine, the tractor isn't picky, but since it lasts so long, a little extra expense really isn't a big deal.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 10:35pm
Even in Alabama, a 15w-30 or 15w-40 oil provides quicker lube to the bearings and camshaft than a straight weight 30 oil will.  That is a good thing.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 12:15am
i use rotella in everything except the 180D, i use 30 wt in it! was told by an old AC man to do that...so i always have!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 12:20am
if you want to clean out the inside of the motor....dunno if that old of tractor has a oil filter or not...if it does, buy 2 new filters. take old one off, put a new one on, drain old oil, fill crankcase with #2 diesel fuel, start tractor, DON'T REV IT UP! just let sit at low idle for about 2-3 mins. shut down, drain again, replace oil filter, let drip an hour or so, replace with new oil! when you dump that diesel fuel out, you won't believe the junk that will come out with it!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 1:55pm
I wouldn't recommend RUNNING it with nothing but straight diesel.  Putting a bit in the oil as a solvent to break up the crud, perhaps, but running it straight is rapidly approaching zero viscosity.  Worse yet, it's loosening up crud and pushing it through the system, which is a treatment much worse than the affliction.
If there's that much crud in the pan, drop the danged pan and scrub it out.
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 5:17pm
I use Restore,it comes in silver can mix with 10-40 oil for my 1962 I40/D!0,tractor holds 15 lbs oil pressure,made a difference when I put it in.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 6:18pm
Bear in mind that due to condensation, a certain amount of water is in all crankcases.  We have used Texaco Ursa in our Caterpillar engines and also used it on the farm for the other JD and IH diesels. Texaco and Shell motor oils are top notch lubricants. We have also used both brands extensively in both opposed and radial aircraft engines. When  engines which used these oils were torn down,  you would find clean sludge free internal engine components.
