changing f2 from wheat to corn |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3949 |
Topic: changing f2 from wheat to cornPosted: 30 Aug 2020 at 11:52am |
what needs to be done to the machine
wheatbreeder
Joined: 12 Sep 2009 Location: Harrow, Ontario Points: 581 |
Posted: 30 Aug 2020 at 12:08pm |
if you have the corn chaffer top sieve change it out with the small grains chaffer
open concave cleance 5/8 -3/4 inch depending on cob size change to corn pulley 20 in dia slow down cylinder speed 250 350 rpm the cob should be rolled out in whole or in half not all cracked up retract fingers in straw chopper
Farm stuff 8050,6690,175,F2,5050,WD
Posted: 30 Aug 2020 at 12:12pm |
Feeder beater must be in the UP position!! Change pulley and belt on the cylinder to 16.5 inch or 20 inch diameters. THIS IS A MUST!! Cylinder speed from 400 to 500 RPM. Raise cylinder to approx. 3/4" clearance. Change to an 1 5/8" corn chaffer. Open the lower sieve quite wide to start. Set fan control to 5 or more. Metal curtain above the raddle remove if it is still in there. Chopper needs to be slowed down or removed.
HudCo
Posted: 30 Aug 2020 at 12:17pm |
sounds like we need to look for a differant seive i know this machine has never seen corn but i know that it has done soy beans
Posted: 30 Aug 2020 at 12:27pm |
A different chaffer, not sieve. What about the cylinder pulley/belt ??? That is absolutely a requirement.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8680 |
Posted: 31 Aug 2020 at 9:06am |
Operator manual would do you wonders. Answers all your questions.
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1360 |
Posted: 31 Aug 2020 at 9:16am |
Filler bars on the cylinder? I used them in corn and removed for grain on k2
SteveM C/IL
Posted: 31 Aug 2020 at 9:27am |
Filler bars have tendency to crack more corn. Would only use in corn you cant get off the cob. Have seen some like that over the years even at 18%.
old farmer
Silver Level Access
Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
Posted: 31 Aug 2020 at 11:47am |
Filler bars also lower the machine capacity
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1000 |
Posted: 31 Aug 2020 at 12:21pm |
have all the parts to change over ,chaffer , pulley , belt , filler bars , black corn heads in a430 , a436 , a438 thanks Steve
wheatbreeder
Posted: 31 Aug 2020 at 2:49pm |
ran k k2 and f2 never used filler bars
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 31 Aug 2020 at 4:58pm |
NOOOOO!!!!!
FREEDGUY
Posted: 31 Aug 2020 at 5:02pm |
ALL OF HIS QUESTIONS ????? I think NOT !!! An OM is JUST like a blueprint, it gets you "close" to the end product but ALWAYS needs "tweaked"
Posted: 31 Aug 2020 at 6:14pm |
Filler bars were only intended to be used for WET corn, say anything above 20 or 22%. It made shelling more complete and created less grain damage because the cylinder speed could be set slower and still do a good job of shelling. It also helped promote more whole cobs, which increases the separation/cleaning shoe capacity. It helped some on sidehills by keeping the crop material spread more across the full width of the cylinder. It was NOT ever intended to be left on the cylinder for doing soybeans or any other crop. Only wet or harder shelling corn.
