CCKA Flywheel Won't come off
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: CCKA Flywheel Won't come off
    Posted: 26 Feb 2016 at 7:22am
Looking for some tips on this.  Trying to pull the flywheel off to get access to the rest of the wiring harness.  Pulley is off, center bolt to crank shaft is out.  I've installed a large 3 jaw pulley onto the fly wheel with the jaws on the ring gear and the center going through where the crankshaft bolt was and it will not come off.  This is the aluminum flywheel.  I put an lp gas infared heater pointed at it for probably 40 minutes and still no luck.  any thoughts?  My dad suggest a plate bolted to the flywheel through the pulley bolts with a pusher bolt in the middle but i'm nervous i would strip the thread holes.  thanks david
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2016 at 7:59am
David
You dad is right ! I just downloaded the Onan servica manual for the CCKA,email me at sparky.miller@cogeco.ca and I'll send the 64 page PDF to you.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2016 at 8:19am
awesome thanks, I drew up a plate to have cut on the laser today that will pull it that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2016 at 11:43am
didn't get my puller burned in time but I remembered dad had a steering wheel puller and that took care of it.
Thanks
David
wdtom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdtom Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2016 at 3:12pm
When you have a puller on something with tension on it it sometimes helps if you give the center screw on the puller a good smack with a hammer. Hit the end of the screw that the wrench goes on, the shock goes down the screw to the shaft and sometimes pops the shaft out of the hub.
