Catchem Live Coon Trap
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: Catchem Live Coon Trap
    Posted: 28 Nov 2018 at 8:11am
I built a nice portable Coon trap using Stock Panel frame Pieces covered with Chain Link Fencing. Top, Bottom, Sides and one end.  The Drop Gate Door is part of my 5x12 Hog trap. Made the same way as the Coon Trap. A Piece of Stock Panel covered with Chain Link fence. Just to look at it, it should hold any Coon That trips the gate.
   When the gate is closed there is a 1 1/4" X 24 opening between the top of the trap and the gate.   I never thought a coon could escape thru a 1 1/4" opening.  I know they can't get thru a chain link fence.
    I have no game cam set up so I'm just guessing the coons tripping the trap are getting out by squeezing thru the narrow 1 1/4" X 24 opening.  I have what I need to close the gap to 1/2 inch before my wife shuts off my supply of Bait.  Purina Cat Chow
    No full grown Coon should be able to squeeze thru a 1/2 crack. Even if his name is Houdini. Or Octopussy.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 12:38pm
A rabbit can go thru a 1 2/4" gap, but big coon,---no way! Are they getting their feet around the door locks?--- I have had them reach around the latches on a very old live trap and get out! Make sure the latches are not reachable from the inside.-- Also if there are more than 1,--the ones still outside will help the trapped one get out! thanks; ac fleet
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 2:50pm
acfleet has some good points.
Also i have a alive trap that a coon at my house and my neighbor's house got out of.  The thing was tripped, and there was no sign of how they did it.  I suspect that there was enough spring/flex in the edge of the trap door that they were able to wedge through it  That trap is the large animal version from Harbor Freight.  you could see where the trap had been moved around/rolled over.
None ever escaped the antique looking trap that i used at my daughter's house in SC.
Strange you should mention that after what my experience was.  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 6:05pm
I closed the crack to less than a half inch.   I studied this trap from top to bottom . The largest way out anywhere are the holes in the chain link fencing. When the gate drops closed a spring loaded  hook at the top prevents opening of the drop gate until I manually unhook the catch at the top.   It would take a coon outside with plenty smarts to unhook the latch.  And.  The latch cannot be reached by any animal caught in the trap.
      I got a camera pointed at trap from the back.   We shall see in the morning everything that happens tonight.
      The Pigs are back too. They left out for a few days. If they show up tonight on the game cam I will go back to trying to catch some porkers.
Edited by Ken in Texas - 28 Nov 2018 at 6:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 6:30pm
I generally prefer the catchem live, then shootem dead traps. My favorite is duke's coon trap, it won't hurt cats or dogs, and the coon can't chew his foot off.  I favor trapping responsibly, check traps as often as possible, they do work.  My favorite bait is cheap stinky cat food, smear on a big marshmallow, and it just fits in the duke trap.  Also, take the juice off the cat food and make a scent trail, about 50 feet, from where traps are set, Just dribble a little, about 2' high on tall grass, brush or trees. Draws 'em in.
For the record, never caught a cat, dog, or anything else in this trap.  Coons love to explore with their front paws, and that's the strength of the trap, and the weakness, of the coon...
[TUBE]klAweWkDMk8[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2018 at 11:03pm
I scared a rabbit out of the dog kennel today.  Went right through the chain link fence like it wasn't even there. If I hadn't seen it, I'd a never believed it!!!  it was a big doe.  I'm still not sure I saw it....  But a coon can't do that, I know.  The two dogs have torn into the coons bad enough and if they get a chance, they go right up the side of that fence to get away from those dogs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 8:09am
The trap can and does catch Coons.  My game cam shows several frames of a very large Coon in the trap.  Also two more on the outside.  Somehow between the three of them they managed let the trapped coon escape.
       Only way out is lifting the drop gate just enough to let the trapped coon out.
     Time to redesign the locking mechanism that is supposed to prevent the gate being lifted even a little bit . Coons are very strong and extreamly resourseful when it comes to getting free
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 9:49am
Wouldn't you be also if someone trapped you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 11:23am
BINGO!!!! LOL!!!---When dealing with coons,--THEY SMART, AND POWERFUL!!! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 1:25pm
I think you got them now Ken.
Looking forward to seeing some pork hanging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 5:52pm
LOL, I can see it now, coon on da inside, sayin to da ones on the outside, can ya hep a brotha out?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 8:02pm
Edited by Ken in Texas - 29 Nov 2018 at 8:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 8:08pm
Look close and count the coons. One in the trap and two helpers on the outside.  Next frame 2 minutes later. No coons
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 10:30pm
looks like you need to spend a few nights out there with a thermos and a rifle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 11:56am
Can you make a triple latch of some sort??---maybe a single with a PICK PROOF top cover.--Keeping it from being opened from outside is gonna be ruff!! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 5:47pm
If they are  big enough and bold enough to help themselves to more Purina Cat Chow and trip the trap the only way they are getting out alive is ME TAKING THEM OUT.  Been thinking ahead to how I'm going do that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 2:21pm
A pair of LONG STRONG tongs??  I ain't helpin, I know just what a pizzed coon can be like!!  They aren't playin none of that "nice kitty kitty" stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 6:28pm
Will the whole trap fit in a 55 gallon drum of water?  They don't swim well, inside a trap...Wink
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 11:15pm
I had been living in our farm here for just about six weeks when I came home from a late shift... about 11pm, on a moonlit night, a racoon picked up a rock in it's mouth, scaled the east face of my grainery building, to the windows up top, took the rock, and smashed the window, climbed inside.
I trapped it with a flashlight and my .25ACP Taurus.  A veterenarian friend advised me once that Raccoons have more nerve endings in their front paws, than humans have in their entire bodies... hence, they can reconstruct a mechanism in their heads, without being able to actually SEE it.  They can also feel you walking towards them... if they're standing still.
