Cast iron valve cover and oil pan WC |
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2041 |
Topic: Cast iron valve cover and oil pan WCPosted: 21 Oct 2024 at 6:07am |
What WCs or other models came this way from the factory?
http://lonsallischalmers.com
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5060 |
Posted: 21 Oct 2024 at 6:31am |
As far as "other models", I have a 42 (wartime) steel wheeled B that has cast iron valve cover and oil pan.
Phil48ACWC
Posted: 21 Oct 2024 at 6:36am |
My '48 WC has a stamped steel valve cover and oil pan. I also have what I believe is a pre WW II WC engine and it also has a stamped steel oil pan and valve cover.
Edited by Phil48ACWC - 21 Oct 2024 at 6:41am |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1127 |
Posted: 21 Oct 2024 at 1:03pm |
I have two cast valve cover and pans, than one on a 57 Wd45.
Don’t think the 57 originally had a cast pan though… |
Lon(MN)
Posted: 22 Oct 2024 at 6:31am |
I have a war time C with cast iron valve cover, oil pan, and cast iron oil pan on each final. So is the cast iron thing a war time install?
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4145 |
Posted: 22 Oct 2024 at 8:30am |
I think that's right Lon. Very early ones may have had them too? I have an iron pan around here for a 201/226 I'm going to put on if I ever get around to building another engine.
Joined: 11 Sep 2009 Location: illinois Points: 88633 |
Posted: 22 Oct 2024 at 9:08am |
the story is that STEEL plate was at a premium during the WAR and was restricted to that use... Cast iron or Cast steel was not as important... Companies tried to SHIFT some of their STEEL parts to CAST to help the war effort.... when the war was over, MOST shifted back to steel plate for parts.
CS_IN
Joined: 04 Aug 2015 Location: NC Indiana Points: 26 |
Posted: 22 Oct 2024 at 10:47am |
What about the WC stamped steel rearend during the war instead of the normal cast iron?
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1185 |
Posted: 22 Oct 2024 at 12:58pm |
All 18 1933 WCs and up to about 700 something (?) ‘34’s had cast iron valve covers and oil pans.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
