Case 530CK Parts Needed!!!
Burns-Tractor-Sales View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burns-Tractor-Sales Quote  Post ReplyReply Direct Link To This Post Topic: Case 530CK Parts Needed!!!
    Posted: 26 Jun 2011 at 2:55pm
I know, I know....... It's the wrong color LOL
but I am in need of a Torque Converter Pump for a Case 530CK loader backhoe.
I bought this machine last summer and it needed work.I took a gamble when I bought hoping nothing series was wrong with it. It has a diesel engine that runs great, it just will not move, I have located the problem and I have removed the torque converter pump. It is in really bad shape, all the gears need replaced, the housing is worn, the bushings are bad and all of the gear shafts are junk. I was wondering if anyone had a pump? I went to a Case "AG" dealer and they can not get the part because this is a construction model and if they could get the pump it was going to cost $900 WOW.... I only spent $1400 on the whole machine LOL....
I need to get this tractor running ASAP.
Thanks for any help
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 4:19pm
There was one of those out on the lot behind my house, but when it was sold to the city for back taxes, it got dragged off somewhere. I do not know where. It was a diesel with a big "inspection port" in the side of the block. Hope you find one.
The guy that has Kutz Farm Equipment in Pine Grove PA is a big Case collector. Maybe they could point you to a parts source. He sells trailers mostly, just get him to talk about Case, there is a wealth of info there.....
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 6:03pm
it does not look bad enough to not make enough pressure to make the clutch work. check the torque converter pedal linkage as just a little bit open will not allow it to work, just dump the oil. check filter also as there it could be blocked and not allowing oil to pass. gear pumps do there job unless totally destroyed. i would put new bushings in it and try it. my brother has a parts machine with a gas engine, i will check with him if it has that pump on it.
This page was generated in 0.409 seconds.
