CASE 530 no spark
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: CASE 530 no spark
    Posted: 19 Aug 2021 at 4:05pm
Went to start the backhoe after setting for 2 months.. No fire.. Crank, crank, crank.. Nothing.. Pulled the distributor cap and rotor cap. Cleaned the point, retry, cleaned the point a second time.. No fire......... Pulled  a couple spark plugs and very very faint spark.. They were 10 year old AC plugs.... Went to shop and grabbed a  couple spare lawn mower plugs and stuck in the plug wire and grounded for a test.. Still very little spark... Figured the coil was next on the list.. Stole a 15 year old coil off the old ALLIS B and put on the CASE. ( CASE had a 10 year or CHINA unit) .. Spark about  5 times bigger.. Still not what i would LIKE to see.. Cleaned the old AC plugs, put back in and it fired off on 3-4 cranks with full choke.
Ordered a new 12 v coil and  4 new NGK 2910 plugs for next week maintenance.
Edited by steve(ill) - 19 Aug 2021 at 4:06pm
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 5:49pm
May be a dumb question but how did the end of the coil wire look? Corrosion in the hole?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 6:02pm
NO... keep it in the shed.... Didnt see any corrosion on wires.. Plug were a little black.. This was a "corn field" fined about 12 years ago.. I rebuilt the motor with new liners / pistons / rings/ turned crank / bearings/ valve job/ etc.. Bought plugs and coil at that time, but NOT the best quality.  Probably has 4-500 hours on rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 6:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2021 at 7:11am
Nice looking rig. That should last a long time time as a casual use machine
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2021 at 11:02am
530 and 580's are close in size. both of my 580 ck's are diesels. wish they were gas! I HATE diesel chit!
You have a nice straight machine there!
