CASE 530 no spark |
Joined: 11 Sep 2009 Location: illinois Points: 90793 |
Topic: CASE 530 no sparkPosted: 19 Aug 2021 at 4:05pm |
Went to start the backhoe after setting for 2 months.. No fire.. Crank, crank, crank.. Nothing.. Pulled the distributor cap and rotor cap. Cleaned the point, retry, cleaned the point a second time.. No fire......... Pulled a couple spark plugs and very very faint spark.. They were 10 year old AC plugs.... Went to shop and grabbed a couple spare lawn mower plugs and stuck in the plug wire and grounded for a test.. Still very little spark... Figured the coil was next on the list.. Stole a 15 year old coil off the old ALLIS B and put on the CASE. ( CASE had a 10 year or CHINA unit) .. Spark about 5 times bigger.. Still not what i would LIKE to see.. Cleaned the old AC plugs, put back in and it fired off on 3-4 cranks with full choke.
Ordered a new 12 v coil and 4 new NGK 2910 plugs for next week maintenance.
Edited by steve(ill) - 19 Aug 2021 at 4:06pm |
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 19 Aug 2021 at 5:49pm |
May be a dumb question but how did the end of the coil wire look? Corrosion in the hole?
Posted: 19 Aug 2021 at 6:02pm |
NO... keep it in the shed.... Didnt see any corrosion on wires.. Plug were a little black.. This was a "corn field" fined about 12 years ago.. I rebuilt the motor with new liners / pistons / rings/ turned crank / bearings/ valve job/ etc.. Bought plugs and coil at that time, but NOT the best quality. Probably has 4-500 hours on rebuild.
Posted: 19 Aug 2021 at 6:09pm |
Boss Man
Posted: 20 Aug 2021 at 7:11am |
Nice looking rig. That should last a long time time as a casual use machine
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 21 Aug 2021 at 11:02am |
530 and 580's are close in size. both of my 580 ck's are diesels. wish they were gas! I HATE diesel chit! You have a nice straight machine there!
