Case 480C backhoe fuel tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Case 480C backhoe fuel tank?
    Posted: 28 Aug 2018 at 9:51am
Anyone here ever taken the metal sediment bowl off of fuel tank? Trying to clean tank on machine and not sure how bowl attaches. Any help appreciated. Thanks tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 6:18am
Most are pipe threaded into a boss built into the tank. Not certain on a Case, maybe do a parts lookup on the case site as to that section of fuel system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 6:22am
Decided had to look!!
https://partstore.casece.com/us/parts-search.html#epc::mr65625ar318907
Appears the sediment section is a component part of the tank, NON removeable.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:10am
wow DUMB.  bout like when they made the sc and dc tractors and then realized they needed a way to steer it.  you see what they got.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 10:33am
I have the manuals. They don't show much as attaching. Does show 2 different tanks, at serial number change. I cleaned it off best I could. It appears to be soldered or welded to tank. The real question is, will tank come off with pulling engine or removing valve cover and rocker assy?  I want to get the crap out of tank.Surely someone knows a good Case mechanic. Any previous know of this greatly appreciated. Thanks Tracy
This page was generated in 0.422 seconds.
