Case 480 backhoe |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10933 |
Topic: Case 480 backhoePosted: 25 Mar 2020 at 8:45pm |
I have a project hoe I am working on. Doesn't want to shift gears. I think the valve than dumps pressure to tranny and torque convert is stuck. Any Case experts on here? Any help appreciated.Thanks Tracy
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 25 Mar 2020 at 8:54pm |
Hey Tracy,,,I ain't a case expert,,,,but I did stay at a motel 6 in Australia,,,,,,,gulp,,,,I'm outa heere,,,,,
Tracy Martin TN
Posted: 25 Mar 2020 at 9:32pm |
Joe, stay safe! Traveling may be dangerous! Tracy
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 26 Mar 2020 at 12:09pm |
Both of mine are 1968 580ck's but same workings. 1 of mine is direct drive and 1 is converter drive. I have never used the converter drive one and only use it for parts hoe ---dont like anything thats not direct drive. I have a bunch of books on 580's and one of them might cover the converter drive unit. I would say that some valve is stuck/sluggish making the trans not release.
Tracy Martin TN
Posted: 26 Mar 2020 at 7:11pm |
ac fleet, mine is a power shuttle shift. Both brakes are on left side. Shuttle disconnect pedal on the right. There is also a switch on dash for drive or road. I think it allows to stop machine with disconnect pedal. I have all the manuals , but must have been written a college professor. Thanks Tracy
Edited by Tracy Martin TN - 26 Mar 2020 at 7:15pm |
ac fleet
Posted: 26 Mar 2020 at 8:24pm |
Hmmmm,---not sure the 580 has any switches,---does have both brake peddles on the right, but so does the direct drive one. Gotta remember to look at it the next time I get to the farm. Drove a Ford 555 that had that setup, ---stomp the clutch peddle, grab trans gear you wanted, dump clutch, mash throttle peddle and go.--- to stop, let off throttle, grab reverse lever and stick it in the other direction and mash throttle again. At idle it just sat there. ---never ground any gears. Took me a while to learn how run it not having an actual clutch !
