Carpal Tunnel
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Topic: Carpal Tunnel
    Posted: 08 Oct 2022 at 7:00am
Wrist has been giving me fits since I broke it in June.
Thumb is numb most of the time, others except my little finger
will do the same randomly. At night is really when it will light me up.
Feels like my hand is on fire, can't touch anything because it feels like I'm picking up a hot skillet and not by the handle.
Had a test done where they put pads on my fingers and shocked me and he graphed it, oscilloscope. Stuck some needles in and did it again.
Yep you have carpal tunnel. Suggested surgery. Went to see the doc handling this says yep I would suggest surgery.
Can anybody tell me anything about this? The way things are going the way it is ain't going to get it..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 7:49am
Had carpal repair done to right hand, basically split heel of palm down lifeline crease, then split the sheath on the tendon tunnel.
Takes about four to five weeks to let it heal appropriately.
Carpal can affect the thumb thru middle finger, outer two, ring and smallest are strictly spinal issues as no tendon tunnels cross those nerves.
May want to speak to a neurologist besides a hand surgeon, sounds more as that have damaged nerve into hand not so much carpal with broken bones, the surgery win’t correct that as I do have that in Left hand where little finger is numb to touch on outer surface, feels like being stabbed or burned if bump it there as has a nerve damage at last joint for it in palm.
dp7000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 8:01am
I’ve got moderate carpal tunnel.
Surgery was an option. I saw a occupational therapist. She helped a lot. Put cushion steering wheel covers on everything. Also anti vibration gloves helped. Maybe those kind of things will help until you figure something out. It’s a big problem. Effects everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 8:05am
That's basically what they both said. Dealing with KS work comp.
Not the best to work with.
Just half my ring finger is involved seems like. Helps if I wear a brace at night but only lessens the issue.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 10:22am
The pinkeye finger numb is generally not the carpal  tunnel. I have that and just living with it, but dose not have the pain my wife had with carpal tunnel.
She has had both done 20 years ago by now. Was no big deal, and she is not a go see the doctor kind of person.
Morpar55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morpar55 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 10:34am
I had my right hand done last year and the left this spring. Two of the best decisions I have ever made. Both incisions were about an inch long and the actual surgery was maybe 20 minutes. I had a desk job at the time and was back to work in a week when I could drive. Had to watch out for how I used my hands for a while afterwards, but with what I was doing yesterday my hands would be worthless today if not for the surgery. Take the hit now and enjoy the lack of pain later on!
1959 AC D17 Gas with some updates
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2022 at 1:07pm
 I had it done a few years ago to my left hand and would recommend it to anyone. Sure beats the discomfort and pain, you can't even see the scar, after 2 or 3 days all pain from surgery went away.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 6:35am
Seems both wrists have problem but for last 10 years I use a brace on both hands at night . Tried brace that holds thumb immobile for a while but now went t obraces that allow thumb to move and a lot more comfortable .
 You can also get a soft brace wrap during the day that just limits some wrist movement , used that when driving for quite a few years , or just a wrist band type that pust some pressure on wrist joint .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 6:55am
Not Carpel T, but the muscle between right pinky and wrist will go into 'Charlie Horse' mode  often. Deep vee , maybe 1/4". Looks real painful to others, I just shrug it off...'oh that ,again'...
Doc in the late 70s sad i have 3 options. 1,go under the knife (hmm, could be a limp wrister if NOT done right) ... pass, 2)pain pills and muscle relax pill (only MASKS the problem,could damage  hand worse , I'll pass , 3) STOP using it..take a break. OK I like THAT option ! I don't swing a hammer anymore, use air nailers and screwguns AND take lottsa breaks ( doctors orders...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2022 at 6:56am
Went the wrist wraps quite a while until they did little good. Mechanic and large handwheel valve manipulation got the best of my hands.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 5:01am
Got the surgery yesterday. Was there 6 hours for a 10-minute procedure. Paper work issues. No one seemed to have there chit together except the Doc. Went to the pharmacy to get pain meds and no one had any. Went to 5 and the last small backwoods pharmacy did. Don't really need much but if they are going to hand them happy pills out I'm going to take them. Doesn't cost me anything.
It's not that bad. 3 fingers are numb and the palm of my hand is a little sore.
Shameless can crank his machine up cause I'm not going anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 6:24am
All that will correct pretty quick, my carpal surgery as noted was just a few minutes, slice hack split and stitch all done but the wrapping!!
Mine has been great since and that in 2017. Buddy of mine cannot thump that area today as sends shooters down his arm, I still use mine for a hammer unimpeded.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 10:06pm
  Hey Fixer,,I'm glad you got that fixed,,!! I have not gone to see a sawbones yet but gonna have to SOON,,!! Mine seems to start under my left shoulder blade and goes down the back of my hand all the way to my thumb and wakes me up 3-4 times a noght and have to use my massager to get the feeling back into my arm and thumb Dang, I Hate thiss getting old chit,,,!!!
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2022 at 9:05am
Make sure you do every thing doctor says for recovery. Including massaging your incision. And don't over-do it or rush getting back to work with your hand.
I had to have BOTH my arms done and didn't do everything by the book and now I still have issues, though not as bad as pre-surgery.
Messaging is very important to avoid hard scar tissue afterwards.
