carburetor kits
6wheeler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6wheeler Quote  Post ReplyReply Direct Link To This Post Topic: carburetor kits
    Posted: 25 Jan 2025 at 1:16pm
Hi all. I am going to rebuild my carb. on my 190XT. The carb number is 13303A. I have been looking for a master rebuild kit. I can only find economy kits. Are there any of these kits available? I don't have it off yet so I don't know how worn the bushings are. Or, if they are even replaceable. I just got the tractor and everything seems good on it. Except the float sticks. I was just going to pull it and clean it and thought I may rebuild it since it is off.  TIA  Pat
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 1:38pm
Zenith/Bendix ?? or Holley ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6wheeler Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 1:48pm
Sorry' Zenith/bendix. #4021805 - 13303A. It is a 1965 190XT
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 3:30pm
At a minimum, you need a needle/seat valve and a bowl gasket and probably a throttle shaft rubber seal.
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 3:41pm
Is this it?
I've bought several kits from this guy, quality has been great.
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 1:58pm
Pat, all you would probably need is the basic rebuild kit. If the throttle shaft has some slop in it, it's the throttle bore that wears out not the throttle shaft so much. So, if it needs the throttle bore redone, bushings or sleeves do not come in a major kit anyway. With all the Zenith/Bendix Carbs I've rebuilt for our customer's, those  particular Carbs usually don't have to many issues with the throttle bore.  HTH
Steve@B&B
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 4:14pm
6wheeler, congratulations on your new 1965 190XT gas!
2x what DrAllis & Steve in NJ replied. Many carb jobs may ONLY realize a thorough cleaning & maybe slight alignment/lubrication of a few pivotal components. THAT IS with some luck, patience, & care given to even aged gaskets, which may be ok to reuse sometimes? BUT then maybe not?? So an economy carb kit (float valve assembly, gaskets, etc) may be all that is required?
One more thing, clean entire fuel tank & fuel lines before attempting to use them.
Edited by AC7060IL - 26 Jan 2025 at 4:15pm
This page was generated in 0.039 seconds.
