Carb part
Orangeinwisco View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeinwisco Quote  Post ReplyReply Direct Link To This Post Topic: Carb part
    Posted: 12 Apr 2020 at 10:13am
I have a MS 464. In the power valve on the bottom there is(was) some packing to seal the needle. Is this available from agco? It does not come in the rebuild kits sold around here. Or what is it made of, can I make something?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 3:33pm
I believe the kit had the new brass screws and any seals were already installed.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 3:39pm
Are you talking about the adjustable jet on the bottom? The needle should have a groove with an o-ring. There should also be a fiber washer to seal the needle assembly to the carb.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeinwisco Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 6:37pm
The fiber washer is what fell apart when I rebuilt. Didn't see an oring on there either. Does anyone know a part number? It's not shown in either of my manuals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 11:25pm
I found it here, but it comes with the power adjuster.  I couldn't find it by itself.
https://www.carburetion.com/products/productdetails.aspx?part=CUD4947
If I were you, I'd call " Steve in NJ " (his handle on here).  It's Steve Barbato  Here's his web site https://www.bb-customcircuits.com/
Go to his web site and then click on More and then Contact.  It's got his number there.  He'll bend over backwards to help you out.
