Unofficial Allis Homepage
Forum Home Forum Home > HELP! > Forum Support Only - No Tractor Questions
cant login
login and email issu View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote login and email issu Quote  Post ReplyReply Direct Link To This Post Topic: cant login
    Posted: 14 May 2019 at 5:45am
Hello,
I am having a issue logining in.  I attempted to change my email to my "normal" email that I use every day.  I have messed up something in the process.  My user name is rhead.  My email as originally input on registeration is rhead78g@gmail.com.  My email that I want this user name to relate to is: rhead78@att.net. (if possible).  I do believe that I have an old login user name of rehpig that is associated with that email and is the reason that things are messed up.  Please, if posssible remove rehpig username.  Put in my new email: rhead78@att.net associated with rhead username.  I have a few posts as well as some private messages with gemdozer that I need access to.  Thanks in advance for your help. Robert Head
Administrator PLEASE View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Administrator PLEASE Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 6:02am
I am still locked out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 7:04am
I assume your problem is solved since I see your last visit to the forum as Last Visit: 7 hours 33 minutes ago at 11:27pm 6/2/2019
Quick Reply
Name:
Message:
   NoFollow is applied to all links from this forum
 Enable BBcodes
Security Code:
Code Image - Please contact webmaster if you have problems seeing this image code  Refresh Refresh Image
Powered by Web Wiz CAPTCHA version 4.04 wwf
Copyright ©2005-2013 Web Wiz
Please enter the Security Code exactly as shown in image format.
Cookies must be enabled on your web browser.
