Can my Maglight be saved,,,,?? |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13751 |
Topic: Can my Maglight be saved,,,,??Posted: 13 hours 19 minutes ago at 4:34pm |
Howdy,,,Here's hoping someone can help with a small Oh- oh,,,, I have one of the 4 battery Maglites that took a dive and started growing some grayish gookies around the batteries and just do not want to vacate the inside of flashilight,,,,,!!! I scraped most of the gookies out but still cannot get batteries to move to try to remove them,,,, Anyone got an idee of what to use to maybe remove this gunk,,,,,???
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25394 |
Posted: 12 hours 45 minutes ago at 5:08pm |
Joe, Im sure someone will come along with some good advice. I had three of them, and had trouble with all of them. Fantastic when they were new, but, even though I changed batteries regularly, whether they needed or not. still got corrosion, and broken switches.
I gave up on them.
I am still confident of this;
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54848 |
Posted: 11 hours 2 minutes ago at 6:51pm |
I'd say a slide hammer with a screw on the tip, drill a pilot hole in the battery, screw in the slide hammer and yank away. Don't do like my brother did he was too cheap to buy a drill bit long enough (stuck battery was down 2 or 3 in the stack) to reach the stuck battery, and sized for the screw in the SH...
AcFordHawk
Joined: 12 Sep 2009 Location: Boone, IA Points: 248 |
Posted: 10 hours 31 minutes ago at 7:22pm |
Unscrew the adjustable light reflector, remove the retaining snap ring, pull the rubber switch cover off, insert a very small allen wrench (can't remember the size) through the switch hole and loosen the screw holding the plastic light holder/batter connection, hold the switch down to clear the body and the plastic part should slide out the light end. At least taking it apart will give access to both ends of the batteries. I have taken a couple apart completely and found the battery acid coating the plastic part. Cleaning is not fun and have tried several ways with mixed results.
IB (restoring), MF GC1705, MF 2705E
Walker
Posted: 8 hours 32 minutes ago at 9:21pm |
If ya got one of them Somali day care centers, your wallet should be able to hack a good slathering of Dielectric Grease. It would be the only thing I'd know of to prevent it. Possibly try rubbing a Mexie skull.
Edited by Walker - 8 hours 23 minutes ago at 9:30pm |
