Can I use an adjustable 336 corn head on 30" rows?
dertz19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Topic: Can I use an adjustable 336 corn head on 30" rows?
    Posted: 05 Sep 2025 at 11:07am
I understand these heads can adjust up to 2"? So that brings it down to 34". 330's are darn tough to find around me, but there's a 336 close by. This is on a K2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2025 at 11:48am
If your hybrids have the ear up off the ground aways, it would work as you can carry the head raised up a bit. You are bending the stalk inward, which is better than outwards. Certainly not ideal.  As far as the 2 inch thing.....a 4-38 head can be made 36 or 40. If it is truly 36 inches, the sheetmetal bolts should be in the middle set of holes.  It might be a 3-38 head ?? set to 36 meaning that's it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2025 at 10:29pm
Thanks for the input. Good point about raising up the header!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2025 at 10:30pm
I was wrong. You are bending the stalk outwards. Not a good thing.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 5:54am
i have done it with a two row head and its hard. With a three row head, the discrepancy is 18 inches. That won't work. Maybe if you only use two rows but i would keep looking
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2025 at 6:28pm
Dertz19, yes as long as corn is standing good(no root lodged or stalk lodged).
Center drive 336’s middle row spot on & two outside rows are each 6” off centered but snouts should direct stalks into snap rollers. Maybe set cornhead sprocket drive to slower speed & pace combine’s forward travel for best results. Adjacent row(s) maybe get crowded away from outer snout’s rear fenders. Drive so cornheads left side slip-clutch’s metal cover/panel is towards harvested side. It sticks out about 6” from edge of fender.
Edited by AC7060IL - 07 Sep 2025 at 6:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 13 minutes ago at 9:32pm
Thanks for the input, I've got time so I think I'm going to hold out for a 330....
