Can I use an adjustable 336 corn head on 30" rows?
dertz19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Topic: Can I use an adjustable 336 corn head on 30" rows?
    Posted: 3 hours 42 minutes ago at 11:07am
I understand these heads can adjust up to 2"? So that brings it down to 34". 330's are darn tough to find around me, but there's a 336 close by. This is on a K2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 1 minutes ago at 11:48am
If your hybrids have the ear up off the ground aways, it would work as you can carry the head raised up a bit. You are bending the stalk inward, which is better than outwards. Certainly not ideal.  As far as the 2 inch thing.....a 4-38 head can be made 36 or 40. If it is truly 36 inches, the sheetmetal bolts should be in the middle set of holes.  It might be a 3-38 head ?? set to 36 meaning that's it.
