Can a 6080 run a White planter blower? |
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 106 |
Topic: Can a 6080 run a White planter blower?Posted: 19 Feb 2026 at 10:56am |
Looking at putting together a 9 row 20" white bean planter. Would a 6080 have enough hydraulics to run the blower and raise/lower the planter, or would i have to use a PTO pump?
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4270 |
Posted: 20 Feb 2026 at 7:25am |
I would think they would but you will probably need to add a 'power-beyond' valve. You'll need someone smarter than me to help with that.
Posted: 20 Feb 2026 at 8:10am |
I've never been a fan of using the tractors hydraulic system to power something like that for hours on end, especially if I could avoid it. The service life of an engine or hydraulic pump is "X" amount of hours at a certain HP/pressure output. So, pick your poison. Use the tractors hydraulic system, and figure on maybe rebuilding it someday down the road, OR use a PTO pump, utilizing it doing what it was designed for. In this case, you have a choice. Sometimes you don't. To answer the original question, your 6080 is probably 12 GPM at the remotes at full throttle, so 6 GPM at 1200 RPM. What does the planter require ??
Edited by DrAllis - 20 Feb 2026 at 8:12am |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3631 |
Posted: 20 Feb 2026 at 9:12am |
Yes, but No, don't try. You need a PTO pump. I run a blower on our 185 for replants etc by taking off the the traction booster outlet on the pump and plumbing it into the blower direct with a 2500 psi safety dump. The motor return goes to sump. Works fine just have to keep the rpm up above 1600. So it doesn't take a lot of gpm. The 6080 is an open center system that has 2 sections - one for the power steering with a pressure relief dumping to sump = you don't want to pressure the return from the steering motor. The other goes to the remotes. You can not Tee into this and unless you devise a flow control , well it gets complicated. A power beyond is used to power the 3 pt and attaching here will kill the blower when the lift/remote is actuated. Get the PTO pump. In the past I ordered a generic pump with way too much gpm and it heated the system even using a L2 gleaner for reservoir and cooler so spend the $ and get the OEM pump with reservoir and remember it floats on the pto shaft - do not bolt it to the drawbar.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2885 |
Posted: 21 Feb 2026 at 6:28am |
I run a Pit Express with one of the 6080’s it does it but not fast. IIRC you have a bigger tractor search out a 8/15 Kinze it will be mechanical driven and a much better planter.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3662 |
Posted: 21 Feb 2026 at 7:30am |
Agree with pto pump choice.
I’m currently configuring a 540 pto JD planter hydraulic pump to run a Kinze 3000 vac & Vset meters. Anyway I see lots of White Air planters using this exact same pump. From your comment/question your White planter’s hydraulics are plumbed for tractor & so maybe no pto pump?? Which is it? Don’t believe Deere mfg it, but maybe mfg’d by Command? Its housing is what I would refer to as a “half-moon” shape. It is an aluminum housing reservoir/pump combination. From searching the internet & talking to owners/operatorsof such pto pumps it appears these pumps produce 5-6gpm volume. Believe the JD(7200s) & Kinze(3000s) use ~ 3gpm for their motors. I don’t know about White planter blowers volume. It’s aluminum housing dissipates some fluid heat buildup, but an in-line radiator(12”x12”?) with no fan is all that is needed to help cool hydraulic fluid. Hydraulic fluid recommendation is 10w(AW32). Most if not all White planter’s blower housings usually incorporate a cooling radiator near their intake to draw air over hyd fluid radiator~ good design. If this JD pto pump is of no avail, think the older IH Cyclone planters pto pumps will suffice? Or if no other options, a older Chevy c10/c20, GM, Ford, Dodge power steering pump can also make do…? Edited by AC7060IL - 21 Feb 2026 at 7:38am |
977.3Ford
Posted: 21 Feb 2026 at 10:43am |
PTO pump is probably something i need to be looking for. Currently have a 6 row Deere 7200 with Precision e-sets for my corn planter, and last year picked up this 12 row 15" White bean planter. Neither planter came with a PTO pump so i've been running both with my 8050 which runs them fine. I'm not sure how much flow either planter requires, but i do know the Precision meters need a higher vacuum and more flow than the standard Deere meters. And even though the White has double the row units it takes far less flow than the Deere. |
Jimmy
AC7060IL
Posted: 21 Feb 2026 at 8:16pm |
Not patronizing this weblink seller, but their used IH 800 900, etc planter’s hydraulic pto pump( the one I previously discussed) has 3 photos of it. It’s listed at $1000, but if you’re patient, others could be located for much less.
https://www.tractorpartsasap.com/hydraulic-pto-pump-used-case-ih-149367c91-411910.html?srsltid=AfmBOooo0AK-PohrzEQA6nzh5cWdBp1KW87ot40LI-Kf-XOCo8PGKzIV#product-description-tabs Here’s is another link of the same sellers past listings for the White 5000s 6000s planter’s hydraulic pto pump(same pump). https://www.tractorpartsasap.com/hydraulic-pto-pump-540-rpm-used-white-432196.html?srsltid=AfmBOor7GcCSf2LWEkvYu31YThpb3xrwu_QYSmUxwuZu600Kc1ND2oo5 Edited by AC7060IL - 21 Feb 2026 at 8:22pm |
AC7060IL
Posted: 21 Feb 2026 at 8:37pm |
Here’s a weblink that shows this pto pump’s specs & port details. They list it as a Webster product (previously Danfoss mfg).
Specs include gpm,rpm,port ID, dimensions, etc. There is also an “open housing” view of internals. https://www.qcc.parts/wp-content/uploads/2025/01/Webster-PTO-Driven-Power-Units-01-2025.pdf Edited by AC7060IL - 21 Feb 2026 at 8:48pm |
