Calling the TBI Experts,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 12:41pm
 I'm getting some "FRUGAL" ideas to  reuse the old one and just solder..
HECK... just hang your ARM out the window !!  Wink
Edited by steve(ill) - 26 Jun 2023 at 12:45pm
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 11:03pm
 Chit Steve, was wonderin when you was gonna put in a presense,,,,WinkWink,
I went and looked at the ones Oriellys and Autozone and even Advance Auto in Roswell and they all had them but to a one,,,,NONE had the same wire color sequence as the original one,,,!!!The old man ar Advance Auto says that sequence is based on factory options so the replacement HAS to be identicle,,,!!
 I'm thinking the thing to dd here is to purchase two 6 pin connector sets and  and just solder in the connectors as the turn signal was workinh good,,,,!!
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 5:00am
If the rest of it isn’t brittle or broken that would be a good option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 12:46am
Joe....try "stovebolt.com" for some/all of your questions. lots of info there. and yeah...i'm alot happier now with you and your newest truck purchase! guess you don't wnt my 454 now huh?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 8:22pm
i read threw this very fast but my new mechanic just done a 1989 chevrolet v3500 cab and chassis 454 tbi tank switch on this has been bypassed and fuel lines run directly to the left tank i know because they had me do that about five years ago .  so i had him check the fuel pump relay first  then injector pulses then next to the tank switch on the dash and it would not ohm replaced that switch and it started and ran for a test drive that was today,  but it took way to long to find the problem hour wise today until i printed him off the wire schematic then the two of us nailed it in about ten minets
