Calling the Friendly Mechaniks,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Calling the Friendly Mechaniks,,,,
    Posted: 13 May 2022 at 3:42pm
  Howdy Friends,,,,Wink
 I believe I already brought this up but with my failing memory,,,and the fact that the issue is getting worst,,,,I come with hands open and  almost on sore knees,,,,,LOL
 On my 2006 HHR I started to get a Check Engine light and Oreilly machine says it was the MAP sensor. Well, I ordered one and finally got it installed ,,,Boy ,,was that a frigging JOB,,,that sob weas under the air intake and wedged up under it and with my big old hands ,,I finally managed to use some long handled needle nosed pliers to get new one back in there,,,Prolly would of been easier to just remove the whole friggin intake,,,!!!!
 When I first fired it up it ran smooth as glass and as I was reaching back to pat myself,,,,the dang engine started to miss and shake same as before and the CE light came back on!!  Drove it around the block and would miss when giving it gas but would smooth out if held at constant speed,,,? When I would put engine under load (low Vacuum) it would miss like heck,,but smooth out at constant speed. Same thing at stop sign,,will mis and jerk at stop IN GEAR but smooth out at stop but in neutral or park??? Looking like it is worst at LOW vacuum AND also under load at LOW Vacuum,,,,???
 I'm wondering if there is a vacuum leak that I can't hear,,,??? The car has 256,000 tenderly used miles,,,,,,LOL
 Any Ideas, anyone,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 4:36pm
15 years old is about right for rubber hoses to crap out.. I would inspect every small 1/4 inch or 3/8 size hose and replace if they have cracks or are hard...
another old trick ( engine setting at idle)  is to spray starter fluid ( or other) in short bursts at various hoses and rubber gasket areas to see if it gets sucked in and changes the idle speed.
dee_veloper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 5:07pm
With the MAP replaced, you should check for new codes to help diagnose the problem.  Getting a cheap scanner will keep you from having to run back and forth to the auto parts store.  Gas cost will likely buy a basic scanner.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 5:45pm
I sincerely hope you get your issue figured out "JOE", but if "I" asked this question, I would have been STERNLY informed to GOOGLE the ailment Wink
Post #'s have their PERKS Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 5:59pm
A stuck or sticking or incorrect for application PCV will cause ALL these issues.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 6:52pm
Respect is earned, not dependent on post #...Wink
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 7:46pm
AMEN
If you choose not to decide you still have made a choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 7:51pm
code readers do solve a lot of problems.. Not all, but they normally lead you in the right direction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 8:05pm
AMEN
And you run a D19??Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 10:05pm
and you wonder why people think (?) your an idiot ?  Big smile  LOL
whats the old saying about keeping YOUR MOUTH SHUT and letting people assume your an idiot, as compared to OPENING your mouth and REMOVING ALL DOUBT ?? Clap
Edited by steve(ill) - 13 May 2022 at 10:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 12:48am
awwwwww....i was gonna say sumpthin...but....
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 6:58am
Do you have a vacuum gauge you can put in it Joe? Smooth and steady or flittering around. Should be at least 16 inches.
A map sensor is a vacuum sensor. Have to find what is throwing it off.
Engine compression should be 180psi. Discrepancies in the readings across the 4 cyls and you may be having a timing chain issues.
Starting fluid is a good idea to try to find leaks around the intake gasket as Steve said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 7:59am
 BE NICE,,!!,,,Shameless,,,!!!  It's too early to start a ruckus,,,,,,,,BY THE WAY,,,How have you and Ms Dee been? Is your Honey doing some better??
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 8:11am
I'll second that.
Despite all the whiz-bang technology touted, the ECM of even today's NEW machines are NOT in any way good diagnostic tools.  Without a healthy understanding of HOW the ECM determines a fault, the scanner's output is little more than a shot-in-the-dark.
From a 'machine thinking' perspective, it can only see sensors, and can only control a few things.  It is programmed to primarily control fuel (by changing the pulse duration of injectors) and ignition (by changing the time of pulses triggering the ignition module(s).
So really, all it's doing from an 'active' sense, is marking time, and pulsing stuff.  The rest is just turning on and off other stuff like... the warning lights on the dash, the AC compressor clutch, the alternator field driver, and the radiator's electric cooling fan.
The SENSORs include MAP, they also usually have an air temperature, engine coolant temp sensor, a crankshaft position sensor, a camshaft phase sensor, a spark knock sensor, and a throttle position sensor.
Each of these sensors' data is gathered, and compared to 'data maps'... arrays of numbers corresponding to what the proper fuel and ignition outputs need to be for any given rpm and loadpoint... at any given engine coolant and ambient air temperature and pressure.
Sound simple?  It doesn't, but it actually IS.  The computer looks at the numbers for each sensor's output, and looks it up on a multidimentional 'map', then pulses injectors and fires spark plugs.
It's so simple, what could go wrong?
Well, at 256,000 miles, just about ANYTHING can upset the apple cart.  As others noted, vacuum hoses, a PCV system leak, a bad ground... a skipped tooth on the timing belt... any ONE of those things.
The computer, however, reports an error code based on whatever SENSOR didn't match up with anything on it's data map.
And it tells you where it 'fell off' the map, either based on either whatever 'bad SENSOR SIGNAL' it read FIRST.... or whichever was the LAST sensor read before 'falling off' the data map.
It is MOST likely, that whatever problem you're having, is related to age and mile wear.  If you were in a less-arid environment, you'd have corrosion as a most likely.
Whatever you do, don't assume that the COMPUTER is actually smart enough to know what is REALLY wrong, because it isn't.  A really good scanner will likely give you a better translation of codes, and let you reset them, and retest, possibly see the ORDER of codes, but never assume the actual code is little more than a 'clue'.  Regular test tools (vacuum gauge, spray-stuff, and a well-tuned hearing-aid for vacuum leaks, compression tester for cyl seal health), a good volt-ohmmeter, and a good service and diagnostic manual on the car is what you really need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 9:02am
Test tools are nice... but a $40. simple scanner can eliminate 80% of the POTENTIAL problems... The "code" does not give you a 100% answer, but it does narrow down the possibilities to a handful of possibilities.
in Joes case, the "code says its a MAP sensor" does not mean to replace the MAP sensor... You need to have the actual CODE... which will give you 3-4 different "possible" causes... There are several CODES that will list MAP SENSOR as a possible problem.
Edited by steve(ill) - 14 May 2022 at 9:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 9:06am
Hard engine faults throw even the best skilled electronics geeks into a tizy, not all faults as to engines are electronics but reflect thru those mechanisms. Low vacuum, vacuum leaks, a bad valve albeit PCV or hard engine valve or a flat cam lobe even a minor little exhaust leak will change parameters enough the engine ECM cannot manage it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 9:17am
Ii dont know what "CODE" was shown, but lets ASSUME it was P0106... this is the GENERIC answer... There could be SPECIFIC items related to a Chevy car..... changing the MAP sensor might work 50% of the time... but there COULD be other problems.
Post Options Post Options   Thanks (1) Thanks(1)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 2:32am
 Well, ordinarily, I would not have responded to a post such as this, but since you directed it to me, I shall attempt to enlighten you. First of all, Neither I nor anybody else on here prolly think to consider post counts as to whether to respond to a particular post or not. While you may or may not realize it, your responses always come across like a finger nail on a chalk board, then you get upset and resort to name calling because you never seem to get the response you were looking for. In every group, there is ALWAYS someone (S) that thinks they have done it all and know more than all others.  Since you joined up, you have made every effort to be that person. I don't think you realize it but with all the questions you are always posting,,,I seriously doubt that you are a "Know iT aLL" type person. Try to "Chill" and accept that someone quite possibly,,,does know more than you do! OR,,,,OR,,they really do not know, so they refer to a search engine so YOU can look for your answer. Nothing wrong with that.
 I myself do ask questions but I also respect that those that do respond quite possibly do not know so they refer me to a search engine ,,,which I do not mind and would never think to BAD MOUTH any responses because they may honestly not know. ,,,,Ya see how easy that is,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 2:56am
 Chit,,,I'm havin one of those "Can't Sleep" nites,,,Soo,,,I'll burn off a little energy and fill ya'll in,,,Wink
 Great News,,,, Fixer and Dave's (2) and Steve,,,,,let me see who else,,,,Clap I went to Oreillys and asked the dude for a printout of their tester and it gave me the code plus all the "possibles" in a percentage formatt and after plugging in all of ya'lls suggestions,, I whip out my can of carb cleaner (much cheeper that starting fluid) Ole Shameless will be so proud of me,,,,,Wink
 I sprayed the intake manifold and didn't find any leakers but,,,,BUT,,in all that rukus,,,I could tell there was a hose that was leaking and finally narrowed it to a 3/8" "S" shaped hose coming from the valve cover to the big 3" rubber elbow that had a small split right at the clamp area and the engine would rev up when I shot some juice at it,,,,,!!!! I Go to Oreillys and they wanted $28 for that frigging S shaped hose bout 6" long, so I get a regulaR 3/8" vacuum hose bout 6" long and it fit like a glove and,,,,and,,that old HHR is now running like new..!!  What was weird is when I first drove it after replacing the hose, the tranny shift points were very high and very hard.  I stopped and started several times til it finally started to shift a lot smoother,,,Wonder what happened?? OH,,and the CEL went off by itself bout halfway home,,,YEA,,,!!!
 Many Thanks to all Ya'll,,,,ps,,,I'm fresh out of Black Label as ole Shameless done took all I had with him on his last visit,,,,,,,ClapClapClap
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 4:44am
Since roughly 1998 all auto electronics are Self Learning.  They adjust parameters of engine operation against changing sensor inputs, changes in altitude or air density or temperatures over time and distance these make fuel controls changes but only to a limited value as cannot compensate for everything.  Affects Trans shift points and inputs to how strong to shift, so what you are feeling/seeing is the processor relearning BACKWARD to a Normal engine not one with severe vacuum leak it was trying to compensate for.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 6:45am
Woohoo!  Nice work Joe!
I'm bettin' something like that happened to our old Montana Soccer Shuttle.  "You need a new mass air flow sensor" would "fix" it for 50-100 miles, "You need a crank position sensor" would fix it for a 100 miless, "need a new this, must be that".....We ended up scrapping the van out as the issue was never found.  The symptoms were exactly as you described in your first post.
Edited by Tbone95 - 19 May 2022 at 6:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 9:12am
Dave hit that one right on the head !! Takes an hour to relearn everything !
GREAT JOB JOE !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 3:01pm
GREAT JOB JOE !!
 Well,,,YOU GUYS are the ones that solved this one for me and soon as I can catch the Black Label on sale again,,,I'll throw a "Get Together" and celebrate,,,,!!
 Seriously tho,, I had always just relied on the tester fellow at Oreillys to tell me something but after listening to ya'll  describe how the codes lead you to the different possibilities causing the issues,,,I asked the dude if I could get a Printout for what the tester was noting. The guy kinda balked and said he would have to get permission from the Mgr,,so I say "Lets go ask!! The Mgr was kinda hesitant ,,so I asked her if she KNEW a Shameless from Nebraska,,and she says   CHIT don't send HIM in here,,,,!!!LOLLOL
 I reminded her that I spend a lot of money in her store and she told the dude,"Print him a copy" Chit,, that copy has a lot of info, and lets you see what the percentages of probabilities it could be affecting the codes. What I really liked is that the dude had told me it "MAY" be the fuel pump ($286),,,BUT that one was way down on the frigging list of possibilities,,,,they would of prolly had me buy a fuel pump and then do like they did to TBone and just keep selling you parts til you either scrap the car or replace every part on the car,,,,!!!
 SO,,,while I have shut down my shade treeing on other people's cars,,I STILL have to maintain mine and the 3 boys that live some close.,,,!  I'ma gonna buy me a good one like they got at Oreillys ($138)  that I can download and PRINT to my desk top. I really like that you can (almost) take the guess work out of them friggin ECM'sClapClapClap
 Don't the ECM's have a small internal battery that will power itself to where you could check some parts at a wrecking yard to make sure it is still serviceable???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 4:32pm
Not really...  and I wouldn't be inclined to get sensors and actuators from a wrecking yard unless I knew-for-certain that the donor was extremely-low-mile and certainly NOT there because of the component.
The sensor that suffers the most wear, is the throttle position sensor... and it wears most in the right-off idle position, and at the position where it tends to sit at highway speeds.  Like the steering worm on a tractor, the TPS spends most of it's time working in one vicinity, while the rest goes mostly unused.
The MAP sensor is usually a peizoelectric device, air pressure causes a sandwich of dissimilar metals and a thin sheet of mica to flex, generating a slight voltage... a good shock in either pressure or physical (whack with a hammer, or long drop onto concrete floor) can cause them to go bad... but over time, the dissimilar sandwich will delaminate, and the thin mica sheet can fracture, then they become erratic.
Crankshaft and phase sensors come in several flavors, one of them is a 'hall effect' device, it's a transistor that, rather than responding to a signal voltage to amplify, it responds to a magnetic field.  Hall-effect devices can fail from being 'oversaturated' with magnetism, or frozen, or shocked, or bit with static electricity.  Another type is 'reluctance', which is a magnetic core with wire coil around it, just like the pickup on your Fender Telecaster... tooth comes by the polepiece, you get voltage swing at the output.  Just like on the guitar, the coils can fail from vibration over time, so they're usually potted in some sort of epoxy, that after a dozen years, slowly shrinks, and cracks, and you end up with the shrinking epoxy ripping the wires in two.
The Exhaust Oxygen Sensor (O2) is a chemical-balance device, it has two dissimilar metals spaced close together, and once at proper temperature, exhaust gasses passing by will generate a voltage based on the amount of oxygen present in the gasses.  In order for it to work properly, it's gotta stay CLEAN, as oil and carbon fouling will cause problems getting a good reading.  They're most likely to foul bad on cold startup, because a cold engine is belching out condensates and excess fuel until the combustion chamber temp comes up, and then they're a bit skunky 'till the crankcase oil temp gets to normal, as that oil is also holding condensation products.  To help make the O2 sensor last longer, there's a heating element in 'em, it forces the tip temperature up, so that it will help 'burn off' crud that's coming by.  Sometimes the heater works better than others, but as an engine gets older, and more blowby travels from the crankcase into the PCV system, there's more unburned crud coming down the tailpipe.  Most of the time, a new O2 sensor won't last too long, as the main problem is a plugged up Positive Crankcase Ventilation system.
There's a whole lot to know... and I'm not the guy that knows it all. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 10:35pm
just so ya'll know...i grabbed as much of that Black Label chit as I could, then almost gots in trouble with the EPA as I dumped it in the road ditch!
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2022 at 11:19am
Wink Well when do we get the report of how good it worked Confused as weed killer or Confused was it fertilizer. LOL Or was it just to over run the stockholder with the homeless following that wonderful aroma.
Sorry Joe, back under my rock I go.
