Calling Pat The Plummer |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Topic: Calling Pat The PlummerPosted: 05 Jan 2023 at 8:54am |
Pat, my favorite throne just leaked water on the floor again. I want to have a plummer trouble shoot and hopefully fix it permanently. Looking for a recommendation. i live between Lake Sangchris and Edinburg. Would appreciate a recommendation, or maybe you roam this far East. Thanks If you can do it maybe PM me your company name, phone No?
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Posted: 05 Jan 2023 at 4:07pm |
Dave... i think you just need to build an Out House and fix the problem for good ..
Dave H
Posted: 05 Jan 2023 at 5:47pm |
Steve, I thought about that, but it just would not be the same with the demise of the Sears and Wards catalogs.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 05 Jan 2023 at 9:08pm |
Depends where it's leaking. Some leaks are not very hard to fix. Ours here in Florida leaked not very long after we got here this fall. One of the bolts that hold the tank to the stool was not very tight, and my wife bumped it and it started leaking. I drained all the water out and added a little sealant to the rubber washer/gasket and put it back together, the nut firmly. No more leaks.
Posted: 05 Jan 2023 at 9:11pm |
Dave... if it continues to leak after you have changed the gasket / seals a couple times.. i wonder if you have a hairline CRACK in the stool ..... bowl or tank ?
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Posted: 05 Jan 2023 at 10:45pm |
Couldn't be a worse time for me Dave. Covered up with work. Maybe Sunday I could drive over and see what I can do. I will send you a pm
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
