Call me a pro!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Call me a pro!
    Posted: 25 Mar 2012 at 10:01pm
Finished up the last brake job this morning with the D17 SIV diesel. It was the last of 4 brake jobs in the last 3 weeks...the others were all 175 diesels.  I think I ran into about every problem that can occur on these tractors and feel pretty good that I conquered them all. I found out that a large area to work, a cherry picker, several parts tractors and an acetylene torch come in very handy. The D17 had a drum that was about 1/2" less in diameter on one side (turned or worn down over the years) and a D19 drum on the other (larger pad than all the others). So, after 4 tractors I used up all the good drums, but have a nice supply of linings for for future jobs as a lot of the problems were not lining related.  Next year it will be the 190XT w/cab :-(
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 10:10pm
Just asking for selfish reasons Eldon ,,, any pics of those rear ends tore apart ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 10:29pm
Sorry Pat...once I get going I "usually" don't take picture breaks. I can say that it isn't rocket science....the "critical" dimension you need to measure becomes clear when you take it apart....and things go a lot faster if you can get that front pin for the 3pt cylinder out right off the bat. I liked having the stack of shims from my parts tractor to use to adjust the "critical" dimension....something most people wouldn't have laying around. I also bought the little aircraft riveter that some on here were talking about a few months back...neat little tool if you want to save some $$$ and do your own re-lining.  I had under $400 cost in 4 tractors!
ALLIS EXPRESS!
This year:
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 12:43am
OK Eldon, You're a Pro!
Allis Express participant
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 4:50am
Way to go Eldon! I know it is such a dreaded job, wow you sure earned your pay lately! Great news!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:14am
Your a Pro if you got paid for for the work done:) I would say you got paid cause you now have 4 tractors with working brakes.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:23am
It's a great feeling to have good brakes!! I did a brake job on a WD45 for a guy that hadn't had any brakes for several years and he made hay with this tractor. He later told me he wished he would have done it years before. Far as I'm concerned its the no. one safety issue.
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:51am
You're a glutten for punishment!
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:51am
PRO WHAT !!!!!!!!!!!!!!!! LOL
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 7:33am
Now that you are a "Brake Pro" --- come on down to KY, got a couple down here that could use your expertise - LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 12:28pm
That's the satisfaction of a job well done.  Way to go PRO!
:-)  I've got a C that needs breaks... Hint hint..
