Cab interior kits for 8000 series
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Cab interior kits for 8000 series
    Posted: 05 Dec 2018 at 3:22pm
Comments, source  and price for cab kit for Allis 8000 cab.
Also the deluxe  brown  plaid seat cover.
The cab kits from Shoup would these be Fehr? Has anyone used Shoup cab kits and how did they fit and look.
Edited by WD45 - 05 Dec 2018 at 7:46pm
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2018 at 7:14pm
Fehr cab interiors is where I've purchased 2 kits from, roughly $500 will do top and bottom. Highly recommend them. Kits are close to perfect match except the posts where a little big on the two I purchased from them. They also include glue which is very strong in bonding. Their window seal kit is a dead on match too. As for seat cloth, good luck. I haven't been able to find a textile place to reproduce it. It someone knew of a place to get it reproduced, I would gladly send a old cover to them to get the pattern copied.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2018 at 8:35pm
Ivan Summerix in Michigan is supposed to have seat covers that are very close to original.  I must also give a thumbs up to the Fehr cab kits.  Finished putting one in my 6080 a few months ago.  Very good quality!
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2018 at 9:15pm
  Try Hy-Capacity out of Humboldt, Iowa. I have used them in both of the 8070's. Drill out the rivets in the two strips at the right side up high at the door and rear side window and the headliner will come down easier. When installing the foam, I dry fit things first. I started at the bottom and worked my way up. In dad's 8050, the owner before us started at the top and went down. The two pieces on the post were stuffed together and it looks bad. If they would have started with the large fender piece, then the small piece on the post, anything extra on the post could have been tucked up under the headliner and the fit would have been perfect. Hope this helps.
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 9:04pm
Where do you get the straps to pull the doors shut?
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 9:41pm
I use Hi Capacity for the upper part and a Ferh floor mat on my 8030.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 9:44pm
  Steve I found my at a salvage yard, take a drill and drill bits make it a lot easier to remove them.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 10:07pm
The pull strap on a 73-87 chevy pickup is a decent replacement. It would need to be cut but they could be made to work
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2023 at 7:33am
WD45, Here’s a March 2021 link to PaFarmer’s 8070 restoration. Similar discussions & ideas in it.
https://www.allischalmers.com/forum/8070-restoration_topic179118_page1.html
Edited by AC7060IL - 10 Dec 2023 at 7:35am
