Cab foam adhesive
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: Cab foam adhesive
    Posted: 02 Aug 2011 at 8:58pm
Some of my cab foam is coming loose. What products work to re-glue it?
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:28pm
Try 3m product in spray can at lowes or home depot.
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 7:19am
3M makes a great spray weather adhesive. Works great on most foams, jutes, and insulating type materials. It also comes in tube form to. Napa also offer's it in tube or spray. Its made by Permatex Corp. The tube version is under Napa/Balkamp part number 765-1463. The headliner and carpet spray version is available under part number 765-1826.  If ya got a Napa dealer near by, should be able to get it... HTH
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 7:34am
3M super weatherstrip adhesive
NEJim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEJim Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 8:53am
Dale, If your foam is starting to come loose, it is probably starting to deteriorate and the adhessive won't help much.  If you rub your hand on it and small particles come off, it's time to replace.
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 12:41pm
Thanks for the info guys. Where can you buy Allis foam in sheets (not a specific cab kit) to redo various parts of various tractors. Is it readily available and how much is it?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 8:41pm
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 9:56pm
Jon Deere also has, comes in a spray bomb
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 10:01pm
Ware a mask and use the spraycan stuff.
