CA wide front steering linkage arms....
Tendencies View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tendencies Quote  Post ReplyReply Direct Link To This Post Topic: CA wide front steering linkage arms....
    Posted: 23 May 2016 at 8:02am
Adjusted the wide front on my CA this weekend and the linkage arms refuse to extend, either completely rusted or??  Tried the blue wrench, 48" pipe wrench, liquid wrench etc...  not much left.....whats a good replacement I can order?? Something off a pickup truck etc?? What size is the ball joint taper....
Thanks
DCC(SW/MTS) USN-Ret. 75-95
51 Allis CA
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 8:54am
Put penetrating oil on and let soak then use a hammer of about a pound and hammer all over it .Lay it on something solid and hammer it and it has tendecy to stretch the metal and it will eventually get loose.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 6:48pm
Soak, heat and hammer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tendencies Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 3:32pm
Well that worked really well!!  Both sliding like new, had to spin the axles around side to side as one of the taper pins let loose and tore up the hole and as long as I had them removed I thought I would widen them a bit.....
51 Allis CA
