CA transmission fill question |
MELCA
Topic: CA transmission fill questionPosted: 17 Jun 2023 at 9:03am |
New member here with a quick question. I recently bought a 1952 CA and am working to get it running again. I think the transmission is filled through the dip stick port where tranny fluid is checked. Is that correct or am I overlooking something?
Grew up on a farm and we had gas 190s and an old Farmall H. Great forum. Thanks |
Ken Mn
Joined: 10 Nov 2021 Location: Zumbrota Mn. Points: 11 |
Posted: 17 Jun 2023 at 10:12am |
Yes you fill through the dipstick using a universal trans hydraulic oil. There are three drain plugs to get all the old fluid out. One under the transmission, one under the differential and one under the hydraulic pump.
Joined: 11 Sep 2009 Location: illinois Points: 88671 |
Posted: 17 Jun 2023 at 12:51pm |
the transmission, differential gear , hydraulics are all combined into one oil cavity with 3 drains... as Ken said.
Edited by steve(ill) - 17 Jun 2023 at 12:52pm |
MELCA
Posted: 17 Jun 2023 at 6:28pm |
Thanks much…
