CA tractor, and 80R
JPatten71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPatten71 Quote  Post ReplyReply Direct Link To This Post Topic: CA tractor, and 80R
    Posted: 11 Mar 2025 at 9:09pm
I have CA that I'm trying to mount a 80R to the back. I bought the manual but it doesn't show pictures whit a ca so was wondering if anyone had one that they could take pictures of? Thanks in advance
Model CA, All Crop 60, Roto Baler
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 10:19pm
I don't know if a CA would handle that mower ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 10:48pm
Do you have correct mounting brackets. Parts book shows which brackets for ca
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 42 minutes ago at 9:32am
my mower for the wd has a mount that goes were the drawbar pins  its  areal heavey mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 34 minutes ago at 9:40am
  The CA is plenty of tractor to handle an 80R mower. Thinking otherwise is like thinking you need a 100+HP tractor to pull a hayrake. I've mowed more acres than I care to remember with an 80R on a CA tractor.
  The proper brackets are needed. If you manual doesn't have the mounting pictures for the CA tractor, the D12 and CA share all the same mounts, which are different than any other tractors. The D10 will share the CA/D12 drawbar mount but uses a different balance bar mount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPatten71 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 2 minutes ago at 10:12am
Thank you all for the response, I do have the one bracket for under the tractor but I think it's not a ca bracket. I'm willing to weld up what ever I need to just don't know where it should attach.
I bought the mower a 3 bottom plow and a 8 ft duck foot plow form a guy for $50 guy got it with his property and had no idea what it was 😂. The tractor my grandfather gifted to me for my highschool graduation. I bought the mower not knowing that he actually had a 80t mower he uses to have back in the day. So I want to get this on the CA to make a good pair
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 21 minutes ago at 10:53am
I’ll look later but the operators manual should show how to mount it. The parts book shows the different brackets needed
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 9 minutes ago at 11:05am
Here is a link to a 4 minute Video of a NF CA mowing with an 80R.
Enlarge the Picture and stop the Video at the 1.0 minute mark for a rear view.
This is a later Model CA with the new Snap Coupler set up.
This may be required because the Mower Mounting Bracket normally gets installed on the Tractor in place of the Drawbar.
Is your Rear Axle Hand Clutch functional because that would be a handy feature with the mower.
G
   https://www.youtube.com/watch?v=_RPkaoPONT4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 53 minutes ago at 7:21pm
Absolutely love the governor action when he makes his turns !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 51 minutes ago at 10:23pm
looks like that handles that mower just fine .  them mowers never missed one blade of hay on the corners
